manifold-turbo bolts keep coming loose!
i've been having this really big problem becuase the studs and nuts holding the manifold to turbo keep coming loose. i had the problem in october so chris (direp972) and i replaced the studs and nuts. it held tight up until just a few weeks ago, and the bastards keep coming loose after i tighten them down. anyone have any ideas? a friend of mine says that i should get a flexpipe welded into the to downpipe to relieve some of the stress on the manifold. is he right? is that what i need to do? any help is appreciated.
HELLO,GOOD MORNIN'
Re: manifold-turbo bolts keep coming loose! (ha illuminato un)
Yep Flex pipes relive stress, but even then they may back out. Mine back out several timse. But a flex pipe will help a million. The vibration of the engine has to be relived somewhere.
Flex pipe will cure your ilness (most of it)...
you've got a fevah, and the only cure is....more flexpipe
mike
mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ha illuminato un »</TD></TR><TR><TD CLASS="quote">anything in particular i need to look for in a flex pipe?</TD></TR></TABLE>
flexyness
mike
flexyness
mike
Re: manifold-turbo bolts keep coming loose! (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN »</TD></TR><TR><TD CLASS="quote">
flexyness
mike</TD></TR></TABLE>
obviously...i was meaning more in terms of length...does it need to be a certain length?
flexyness
obviously...i was meaning more in terms of length...does it need to be a certain length?</TD></TR></TABLE>
i usually order 6 inch flex pipes.my friend bulldogg83 was having the same problem(except he already has a flex pipe), so i added some loctite, and he's been good ever since.good luck
Smarter than you
A flex pipe would definitly help a ton.. After that, id suggest you have a shop fabricate a bracket that welds to the downpipe(before the flexpipe) and bolts to the bottem of the motor.. This should ensure that all the flex happens where it should; at the flex pipe.
haha, hope you get things all ironed out
mike
mike
get a set of bolts with wirelocking holes in them and just tigthen them down and wirelock them.
87 SiviK Si
09-03-2010 09:17 AM
Ekzc91
10
04-15-2009 10:42 AM
