M&W PRO 10 Help
I connected everything the way it says in the instructions. I connected the ignitor to A21 ICM. Car does not start and its giving me Ignition output signal code.
What's the problem? |
are you trying to bypass the ignitor completely?
Re: (Jared)
yes
I took the coil and ignitor out of the dist. I got the ICM pin from ecu to M&W Box. Then from M&W box to coil. |
Re: M&W PRO 10 Help (Turbocivic94)
Hit up Tony1 is my suggestion
Bump, Because I will be installing mine soon.
should have went with msd.. https://honda-tech.com/forums/images...s/emsmilep.gif
subscribed because I hate honda ICMs. |
Re: (2point2)
well, I spoke to tony and I still cant figure out the problem. I had to put back the factory ignitor in the dist. I did that, car still does not start. I put a factory dist and started right up.
I dont understand why I would need the factory ignitor if M&W does the samething. If the ignitor is in the dist, it still does not get signal from ecu cause signal is going to M&W box. Everything is wired correctly. I'm getting code for ICM. Maybe I should have bought MSD cause its pissing me off. |
| All times are GMT -8. The time now is 07:24 AM. |
