LST / LS-T Turbo B18A B18B setups
Old 04-21-2018, 06:45 PM
  #32451
Default Re: LST / LS-T Turbo B18A B18B setups
supersilverdc2 is offline
Old 04-22-2018, 05:35 AM
  #32452
Beast mode!
b16racereg6 is offline
Old 04-25-2018, 07:14 PM
  #32453
What's up everyone, I've read a few posts on this thread here and there and just wanted to ask a few questions. I have a 96 hatch with a b18 boosted, je 81mm pistons, eagle rods and head studs. Had some crower cams and some super tech valve springs and retainers put in. Precision 5857 journal bearing with ID 1000 on e85, old skunk2 intake manifold with a 70mm throttle body. Inline pro log manifold 3" exhaust. Made around 350 to the wheels on about 23 pounds. Kinda expected more honestly but I'd say the tune is conservative. Have almost 3000 miles on it since it was boosted and tuned. I really thought I would have made around 400 but not sure if it's the log manifold and old skunk2 intake manifold holding the car back a bit. Was thinking of going with some type of ram horn manifold but was stuck on what type of intake manifold would be better if any noticeable gains over what I have now. So it being 2018 what intake manifolds are the best choice. Not sure if Skunk2 ultra is only offered for Vtec heads or at least that's what I saw with a quick search. Do you guys think I'm right at where the car is supposed to make based on my setup or should I be seeing slightly higher numbers? Not sure if the dyno was one of those heartbreaking dynos lol. Anything else I should look into or should I try maxing out the turbo to see what it has? Reliability is a big factor so I may end up just sucking it up and enjoying what I have, and the engine is not sleeved so I know 400-450 would be my limit if I am able to get more power out of it.
ezdoesit93 is offline
Old 07-03-2018, 08:18 AM
  #32454
https://youtu.be/eTB7m4tGEAI
Just broke into the 600+ club with my straight LS build.. stock sleeves CSS support and stock ports on head.. gtw3684 at 32psi on 110 octane race fuel.. stock fuel lines, grams 320lph and grams 1150cc injectors.
Turbo Bseries is offline
Old 07-03-2018, 01:32 PM
  #32455
boosted94gsr's Avatar
Nice work man! What cams and valve train? Crower 404?
boosted94gsr is offline
Old 07-04-2018, 06:32 AM
  #32456
Yes crower 404 and brian crower dual springs and retainers, also ferrea valves 6000 series, skunk2 manifold and 66mm throttle body.
Old 07-05-2018, 03:44 PM
  #32457
Berto24's Avatar
Very nice Congrats!! Not so many straight ls 600whp+ builds around
Berto24 is offline
Old 07-05-2018, 04:00 PM
  #32458
Berto24's Avatar
Rip stock sleeves, they found their limits at 505whp on pump 93
Berto24 is offline
Old 07-05-2018, 05:33 PM
  #32459
got a datalog from the run?
ls joker is offline
Old 07-07-2018, 08:52 AM
  #32460
That was my goal all along to make 600whp since i dont know of many people that push the LS that far, it can make more with better cams a bigger turbo and a better intake manifold, twin disc clutch and it could break 700whp easily.. but i am staying at 600whp for a while.. 700whp means i will need alot mlre stuff to reach that..
Old 07-17-2018, 07:00 PM
  #32461
Berto24's Avatar
maybe I have something what are you interested in?
Berto24 is offline
Old 07-17-2018, 07:03 PM
  #32462
Berto24's Avatar
is a matter of time now to reach those 700whp haha
Berto24 is offline
Old 07-17-2018, 07:09 PM
  #32463
Berto24's Avatar
Shodan this one is for you what do you think . I am in some kind of indecision 6466 t3 .82ar or 1.15 t4 divided. Looking for 850whp. No more street racing for me. Will focus now on the 1/4 mile. If .82 I will stay with the ram horn if 1.15 i will switch to a sheepey divided front mount.
Berto24 is offline
Old 07-18-2018, 08:30 PM
  #32464
Moderator
TheShodan's Avatar
For that size you're looking at, why limit to only those two sizes? A .84 T4 divided in a kooks will do fine for 850whp.
Going front-facing does nothing but cause oiling issues, and unnecessarily destroyed turbochargers. Don't go that route, unlike you have several turbo replacements handy.
TheShodan is offline
Old 07-19-2018, 09:38 AM
  #32465
Berto24's Avatar
Might change to a top mount not enough capital for broken turbos. Anyways I ordered the turbo last week .82 t3 but since I am going to change the turbo manifold might as well optimize things. So do you think the divided t4 .84 housing will carry the power to at least 9500(obviously with a good head combination) because i know the spool is going to be improved.
Berto24 is offline
Old 07-20-2018, 09:20 PM
  #32466
Moderator
TheShodan's Avatar
Spool won't be improved, just higher output. Don't let the divided housing full you. Plus, going top mount destroys any possibility of using the word "spool" ever again.
Just drag race the car. Spool won't have anything to do with what you're doing anyway
Old 08-12-2018, 08:47 AM
  #32467
7passu's Avatar
Has any tried the crower turbo specific cams with any luck? or is the 404 the best off the shelf cam your going to get?
7passu is offline
Old 08-13-2018, 10:57 AM
  #32468
LightningTeg's Avatar
The 402T will drive like a stock car out of boost and makes some good gains over stock. 404s drive pretty well and make great power for non vtec, but you'll notice the difference put putting around. 405s are strictly race cams IMO. Havent seen many turbo builds with them.
LightningTeg is online now
Old 09-03-2018, 12:35 PM
  #32469
K7-1Ktrevor's Avatar
K7-1Ktrevor is offline
Old 01-17-2019, 06:54 PM
  #32470
Anyone using Delta 282/272 regrinds?
90turbols3431e is offline
xx1bad1integra8998xx
03-31-2016 05:41 PM
Quick Reply: LST / LS-T Turbo B18A B18B setups
  • Ask a Question
Question Title:
Description:
