LS-VTEC Turbo or LS Turbo ? WWHTD ?
Here is my dilemma, I want to get back into the Honda game. Been out of it for a few years now and want to get back into it.
If I do LS-Vtec Turbo, the block will be bone stock, with a thicker head gasket (to drop compression), with a Vtec head on it. Maybe some 01Type R cams and a free-er flowing intake manifold but pretty much it will be bone stock LS-Vtec.
Then, the LS will just be a bone stock LS slapped on with a turbo kit.
The turbo kit will have decent parts. Some mini ram horn AC from one of our vendors, Silver Surfer Turbo, APEXI Intercooler, Usual Tial stuff etc..
Of course it will get the best tuner in my area to tune it..
My question is now....
How reliable would the ls-vtec be interms of boosting it, especially with the thicker head gasket getting the most whp I can get.
OR..
Should i stick with just boosting the LS and be happy with that?
Would the HP gain with the LS-Vtec be worth it, but sacrifice reliability ?
Any feedback is greatly appreciated!
Thanks!
OR..
Thanks!
Re: LS-VTEC Turbo or LS Turbo ? WWHTD ?
My personal opinion is and ls-vtec would work fine but the issue is most people try to rev their LS Vtec's like they are a gsr or type r motor. Thus causing the bottom end to go boom... Personally I would put some aftermarket pistons and rods in the block then call it good. I mean for 5-700 dollars you could grab some eagle rods and cp pistons.. Or find some used ones for 300 bux.
If that sounds to scary to you just stick with an LS turbo..
Moderator
LS-VTEC (STOCK headgasket), hands down.
-no need to drop compression, and reliability doesn't suffer. You've definitely been out of the game, as those are no longer an issue.
Plus you have LOTS of camshaft choices for later if need be
I guess there you go. LS-V get that running top notch first, then slap on a turbo kit. Gotcha. thanks again Shodan. just getting back into the game. its all foreign and familiar at the same time!
Yeah boosting LS Vtec is no longer an issue with the better tuning programs out there the days of the VAFC/SAFC and FMU are long gone. LS Vtec motors are very reliable when done right, I DD mine and it sees 8000 RPMS regularly now for 2 years and no issues. I do have ARP rod bolts and Hondata tuned. I plan to boos it in the near future once I can put a turbo kit together.
