Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   LS rods on boost (https://honda-tech.com/forums/forced-induction-16/ls-rods-boost-966724/)
shiftgear8000 Aug 21, 2004 09:35 PM
LS rods on boost
Was thinking about boostin the motor w/ the LS rods and CP 9:1 pistons.....how good will the rods hold up? How much power/boost????
-jase
TurboCoop Aug 22, 2004 06:04 AM
Re: LS rods on boost (shiftgear8000)
I want to know the same thing, I just got my SRP 9.2:1 pistons and a block guard and I was wondering if I should get rods too, or if not how much boost I can run with the stock rods and this setup?
boost fed ls Aug 22, 2004 06:45 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiftgear8000 &raquo;</TD></TR><TR><TD CLASS="quote">Was thinking about boostin the motor w/ the LS rods and CP 9:1 pistons.....how good will the rods hold up? How much power/boost????
-jase</TD></TR></TABLE>
I dont mean to sound like a dick but why would you use cp pistons with stock rods? You should have replaced the rods as well. If you would have used forged rods you would have had no problem boosting 15psi and more with good tuning. Anyways if you had it tuned well you would have no problem with 10psi, I run 9psi daily and 11psi at the track and I have stock pistons and rods. Rods are the week point when boosting much more than this.
turboimports Aug 22, 2004 06:53 AM
Re: LS rods on boost (boost fed ls)
I say the rods should handle at least 7lbs....try boosing it up a little at a time, if it starts to run funny...time to boost down... your car blows....haha
-Lor
Joseph Davis Aug 22, 2004 06:58 AM
Re: LS rods on boost (turboimports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboimports &raquo;</TD></TR><TR><TD CLASS="quote">I say the rods should handle at least 7lbs....</TD></TR></TABLE>
What does 7 lbs have to do with how much compressive load they can withstand?
Code Blue Aug 22, 2004 07:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboimports &raquo;</TD></TR><TR><TD CLASS="quote">I say the rods should handle at least 7lbs....try boosing it up a little at a time, if it starts to run funny...time to boost down... your car blows....haha
-Lor</TD></TR></TABLE>
wow, thats good advice.
ya der buck, just crank the boost, and if you hear shit break, turn it back down. people like you give backyard mechanics like me a neverending line of cars to work on https://honda-tech.com/forums/images/smilies/emthup.gif
edit. my best suggestion would be to at least upgrade your rods to eagle, if it was me, it would be done just for peace of mind. they aren't that expensive either
Joseph Davis Aug 22, 2004 07:44 PM
My best bet is to tune the car well. Stock LS has good reliability at 250 whp with the usual kit setups... 275-300 whp stock block are not unheard of, although lifespan is much shorter. At those power levels, you're making more torque than 600+ whp boosted B16's; it's the torque tears the rods apart - or detonation if your tune is screwy because you "ran more than 7 psi.".
Garcia-Racing Aug 22, 2004 09:57 PM
I made 300 on LS rods....in my single cam.
civtegra_hybrid Aug 22, 2004 10:10 PM
ls rods can handle up to 300 hp FACT.
