LS Crank ok for golden eagle main girdle?
I have a B18A block with a golden eagle main girdle kit. Would a LS crank would still fit or I have to use a GSR crank thanks.
Re: LS Crank ok for golden eagle main girdle? (integraboosted)
well since the ge main girdle is pretty much an exact copy of the oem stock gsr girdle yea it will work.
Re: LS Crank ok for golden eagle main girdle? (manikGSR.)
What about a balanced and micropolished LS crankshaft would it still fit with a girdle kit for an LS block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraboosted »</TD></TR><TR><TD CLASS="quote">What about a balanced and micropolished LS crankshaft would it still fit with a girdle kit for an LS block?</TD></TR></TABLE>Yes.
Re: LS Crank ok for golden eagle main girdle? (V-SPEC 1)
Well first things first you need the longer GSR main studs which should be the ones in the kit, and as far as a line bore that is strongly recommended. it wil bolt up to the mains, but as far as the oil pick up, windage tray, and oil pan you will have to switch over to GSR stuff for extra clearence to fit the girdle.
b18, crank, crankshaft, crankshafts, eagle, girdle, golden, install, installation, integra, kit, ls, main, oem, review
