ls/b18b turbo people- who is doing 300-350whp on stock head??
well im contemplating some pistons/rods/headstuds for my b18b, but im not gonna have money, especially right away to do any headwork. i know the ls head is not the best flowing, and has a tendancy to drop power after 6000-6500 rpms.
im looking for about 320 or so whp if i do this, which i was thinking will be 15-18 psi with my 57 trim t3/t4( my setup is capable of this, but i dont think my current block is), im just not sure if the head will really get in the way of my goals. what is everyone else out there doing???
Re: ls/b18b turbo people- who is doing 300-350whp on stock head?? (blackeg)
I built a friend's LS motor more than 2 years ago, and it had only piston, rods and block guard. bone stock LS head w/ skunk2 manifold and made 417whp and 340 lbs.trq. to the wheels. Until this day, he's still running the same setup and running strong. Check out masetuning.com I think the car still on his website. It's the yellow coupe w/ carbon fiber hood. It was running pretty rich at some point like 10.1-11.1 afr. we could have made more if we did not run out of time. It was like 3 a.m in the morning. It's the only LS motor setup that it's in the site. Everybody else running VTEC setup.
Modified by V-SPEC 1 at 2:48 AM 7/4/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">well im contemplating some pistons/rods/headstuds for my b18b, but im not gonna have money, especially right away to do any headwork. i know the ls head is not the best flowing, and has a tendancy to drop power after 6000-6500 rpms.
im looking for about 320 or so whp if i do this, which i was thinking will be 15-18 psi with my 57 trim t3/t4( my setup is capable of this, but i dont think my current block is), im just not sure if the head will really get in the way of my goals. what is everyone else out there doing???</TD></TR></TABLE>
I have an LS with cp pistons, eagle rods, stock sleeves and ge blockguard. The head is stock and so is the intake manifold. At 18 psi it put down 354 whp and 309 ft/tq. I'm running the basic garret t3/t4 57 trim turbo with .63 ar hot side. This friday I'm going to have Mase retune it on race gas this time. Last time he tuned it I was running a 50/50 mix of 91 unleaded and 100 unleaded. I hoping I can make close to 400 whp with open downpipe and some leaded race gas. I'll post the dyno sheet after Mase tunes it.
Although the LS head does suck compared to a vtec head you shouldn't have a problem meeting your goal of 320 whp. I've heard of people putting down over 400 whp on the LS head. Goodluck on your setup.
Re: (wisjdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wisjdmhonda »</TD></TR><TR><TD CLASS="quote">bump for more info im looking to do the same thing.</TD></TR></TABLE>
Not a whole lot to it.
350 hp capable turbo
+ fuel/mods to support
+ decent engine management
+ properly tuned
350+ horsepower LS
+ properly tuned
350+ horsepower LS
Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource »</TD></TR><TR><TD CLASS="quote">Not a whole lot to it.
+ properly tuned
350+ horsepower LS</TD></TR></TABLE>
i think im pretty much there...
550's
walbro 255
3" downpipe and no cat
uberdata tuned with my lm-1 wideband...
how much can i get out of the 550's? about 350 whp max? i still run stock fuel pressure
+ properly tuned
550's
walbro 255
I have a feeling more and more 500+ WHP LS's will be surfacing. . .
With headwork, it's a bad-*** machine. . . more torque than you'd ever need, and plenty of horsepower to take over on the top end.
I'll sure drink to more 10 second straight LS's.
Re: (19sec beast)
3 years ago i put 310 down at 11 psi with just pistons rods blockguard and stock head with 440s and an afc
still running straight ls but very different lookin for high 500s low 600s hope to see soon
Re: (9SECQTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9SECQTR »</TD></TR><TR><TD CLASS="quote">3 years ago i put 310 down at 11 psi with just pistons rods blockguard and stock head with 440s and an afc
still running straight ls but very different lookin for high 500s low 600s hope to see soon</TD></TR></TABLE>
hudson valley represent.
310 is big #'s for only 11 psi, most ls's i see are around 250 at that level. what turbo was that with?
Re: (blackeg)
my sig on 16PSI (conservative timing). Stock LS head and internals. I'm hoping a nice port and polish will help out quite a bit once I build the internals
you could make that with pump 93 no problem assuming forged pistons and rods. A typical 54mm garrett or turbonetics would make that much around 20-25psi
erebunicrx
06-03-2005 06:52 PM
Mr.DC2TurBo
03-23-2004 06:03 PM
