Lossing boost, any other possibility besides a charge pipe leak?
I started lossing boost today. I did a compression check and had 210 straight across, which was a big relief. I check the BOV and it seem to be functioning. I guess I should check the intercooler, which I will do right after this post. Anything else?
Nick
Nick
Re: Lossing boost, any other possibility besides a charge pipe leak? (Sinner)
check your vaccum connections. If you taped your bov right between your FPR and IM, check to see if that came off. If not, check all your vaccum sources. I don't think it would be your intercooler because the tank should be sealed. But then again if you got it used and they didn't do a leak test, then maybe it's the ic
