Looks like Golden Eagle F'ed my block !
Well the car started today, and it is leaking oil on the back of the head where it connects to the block in two places...Looks like GE milled it too much, or too little. Hopefully we can torque down the head about 10ft/lbs more and It will seal, if not , back to the damn machine shop...This is another foul up by Golden Eagle, the first thing they did was not even tell be about the motor needing to be line bored. They just did their work and sent it back, I could have bolted it in and all the main bearings would have been ruined. I took it to the machine shop and they said the Line Bore was way off...AND they took about 2 months with my block...Thanks Golden Eagle !!!!
Re: Looks like Golden Eagle F'ed my block ! (simple4012)
what head gasket do you have?
What did you torque the head down too?
What head studs you have?
H22A4 Specifications
Stock until the ARP's arrive, we were tired of waiting for them so decided to use stock until the ARP's came ...
Re: Looks like Golden Eagle F'ed my block ! (C-Redrum)
Stock until the ARP's arrive, we were tired of waiting for them so decided to use stock until the ARP's came ....
Yes it sucks big time, i hope torquing the head down more works...crossing my fingers....ive been waiting for my car forever...We did start it though, sounds beast with the Crower Turbo Cams, HKS BOV, 3 inch exhaust....cant wait to get it running !
Dont re use head studs!! you should know that!! especialy after building younr engine!!!! GET NEW ONES!!
technically you're supossed to get new ones every time you take off the head.
Guest
Posts: n/a
Re: Looks like Golden Eagle F'ed my block ! (sutrusu)
where the **** did you get your hands on those crower turbo cams?!?!?!?! they told me that they didn't have any, and wouldn't have any made until the first of the year, and they told me this like 4 months ago
Re: Looks like Golden Eagle F'ed my block ! (Boosted97Lude)
I would probably verify that GE fucked up by getting a manchine shop to check the specs before bashing a company when it could very well be your fault.
Get your sleeves checled make sure they have not sunk or dropped. Could be a GE fault maybe not. Check it out, take it to reputable machine shop. Good luck.
Re: Looks like Golden Eagle F'ed my block ! (Boostfed)
why would it be GEM's responsibility to check the line bore of your crank? did you tell them to do so?
you know what... if they did..it sucks..but im sure they will fix it..
NO ONE can have a 100% success rate..theres bound to be a few bad apples in the bunch.... and your just the unlucky one..but im sure they will do somethign about it.
Re: Looks like Golden Eagle F'ed my block ! (qwkteg125)
Re: Looks like Golden Eagle F'ed my block ! (SiRkid)
not to sound like a retard, but when i first put my engine together, it shot oil everywhere at high pressue from between the head and block. turns out in my eagerness to start the car i put the head gasket on backward just a thought. good luck.
because when they sleeve the block, they screw up the line bore....
Re: Looks like Golden Eagle F'ed my block ! (apexii)
God forbid you ask Ted about this one......... My motor needed the sleeves pressed out and new ones put in, I asked about a line bore, Vince blew me off like a 2$ *****, Ted responded like my assuming I needed a linebore was very inaccurate.... All I know is this bitch better not leak when it goes together.
