LOOK!!! Block Inside Need BIgger Turbo and HELP!!!!!!!!!!
Ok i blew my stock b16 turbo and replaced it with the setup listed below..Setup has about 325 miles and is broken in and ready for a turbo in another 100+ miles...my goals are low 12 second car/high 11 second car on high boost....and a daily driver on low boost...so what turbo meets my goals....i was thinking a garrett t3/t4 57 trim....what do you goes think
Block
B18a1 block
Scat H Beam Rods
Arp Rod Bolts
Arp Headstuds
Mahle 9:1 Compression Pistons
b16 Vtec Water pump
B16 Vtec Oil Pump
Acl Race Rod Bearings
New HOnda Oem Main Bearings
New Oem Headgasket
Stock Sleeves
Fuel System
Walboro 255 Fuel Pump
Dsm 450cc Injectors
Hayame Fuel Rail
Hayame Fuel Pressure Modifier
B&M Fuel Pressure Gauge
all goes into a 1989 honda crx si
Block
B18a1 block
Scat H Beam Rods
Arp Rod Bolts
Arp Headstuds
b16 Vtec Water pump
B16 Vtec Oil Pump
New Oem Headgasket
Stock Sleeves
Fuel System
Dsm 450cc Injectors
Hayame Fuel Rail
hotimportcrx
19
10-11-2005 09:46 PM
hotimportcrx
09-04-2005 09:44 PM
