Leaning out with FMU and only 5 lbs.
Any thoughts one what the problem is? This is a Greddy kit on a ZC. The car leans out as the turbo spools. By about 5000 rpm, the a/f is going in to the red (I back off then obviously). I'm using a 12:1 FMU. Is it possible that my fuel pump can hold up to the 5lbs? I would think it could hold at least 5 lbs with no problems. Is there any way to confirm that the FMU is working? Should I take it apart and make sure it has the 12 disc? How can I tell?
Thanks,
RYAN
Thanks,
RYAN
Re: Leaning out with FMU and only 5 lbs. (Hassan)
check the fmu...cause you shouldnt have any problems at 5 psi...maybe your boost guage is wrong..and ur boosting more thats why your leaning out..
Re: Leaning out with FMU and only 5 lbs. (therealciviczc)
When you raise your your fuel pressure, the volume of fuel the pump can flow drops. Check out http://www.hondata.com/techfuelpump.html
Doug
Doug
No fuel pressure gauge...
it looks like I'll be getting one though!
This is the first day that I've had the turbo. All of the hoses on the FMU appear to be correct, and its all new hose, so I doubt there are any vacume leaks.
My boost gauge isn't hooked up yet because I have to pick something up at a place that wasn't open on sunday. I just wanted to take if for a spin and noticed that it leans out very badly.
Is there any way to tell if the FMU actually has a 12:1 disc
Re: FMU (therealciviczc)
So do you think that the 12:1 is just too much for the injectors to keep up with?
Re: FMU (maxim)
I replaced the pump, and every thing is fine. It stays in the green under acceleration. The only probelem so far was the fuel pump blowing the fuel pump fuse. I think that was only due to the fuse having 170,000 miles and suddenly getting something that pulls more current. Could also be that my entire car needs to have a better ground.
