leaks from manifold to turbo
hey guys i ahev leaks all around from my manifodl to turbo what kind of hi temp sealer can i use to seal them up i don't think i can get the bolts loose to rplace the gasket
thanks will
thanks will
Re: leaks from manifold to turbo (blackccoupe)
try to get the bolts loose and use high temp rtv copper silacone sealant with no gasket, just spread some on both the manifold flange and the turbo flange, your fingers work best to spread it, let sit for two minutes and bolt them together that should give you a good seal
prolly gonna have to take the mani off, to get the turbo off. then replace gasket coverd with copper gasket maker!!!!
no way i can just spead it round the edges where it's leaking huh cause it looks like the blots have never been loosned don't want to turn into a head ache ya know
2000__GSR
06-15-2004 05:31 AM
