K20 O-Ringed Block coming up. Which Head gasket do you recommend?
I got nice results with O-ringed d-series Block and oem head gasket. Never had problems up to 500whp. So now im thinking about a k20a2 88mm bore. If o-ringed - what head gasket Should i use? (golden eagle? Cosmetic?)
Or better to bore it to 87mm and use k24 oem head gasket? if this post is not correct here - please move it to K-Series section |
re: K20 O-Ringed Block coming up. Which Head gasket do you recommend?
golden eagle headgasket.
Golden Eagle or JE Pro Seal.
with 87mm i can use the oem k24 head gasket?
Originally Posted by strigga
(Post 51741136)
