just installed my DRAG3 and i need some help PLEASE!!!!!
New User
my engine stays at the rev that you shift at and then slowly goes down, i have a VAFC and a o2 sinulator in my ECU, but i dont know what would cause it.
Re: just installed my DRAG3 and i need some help PLEASE!!!!! (jdmR)
throttle cable stuck? i had that problem after i adjusted the throttle cable.. i had it too tight and it would idle at whatever i left off at...
check to make sure notihg is obstructing it.. like when car is off, rev engine from the engine bay and see if it returns to normal..
any vacume lines not hooked up? vacume leak?
where is everything T'd off of?
whats the vacume at idle??
what is your entire engine/turbo setup ???
more info dude!
more info dude!
Re: just installed my DRAG3 and i need some help PLEASE!!!!! (GSRwBOOST)
If you are saying that your rpms dont drop when you shift then I am guessing you need to take your foot of the gas pedal before you press the clutch.
Nah, but seriously your throttle cable could be stuck. TB butterfly is stuck open or you may need a new clutch. Any of them could be the problem. IMO
New User
Re: just installed my DRAG3 and i need some help PLEASE!!!!! (2000_Civic_Si)
one of your vaccum lines could be in the way of the throttle cable...i had that same problem once.
danielfleenor
04-10-2008 05:16 PM
