JunVillaruz's PTE6766 T4 2.1liter GSR new project build
#51
Re: JunVillaruz's PTE6766 T4 2.1liter GSR new project build
https://www.d-series.org/forums/show...d16-build.html
#53
Just got done working on the car and she’s finally back on the ground and now with new injectors and driveline. Most shops are closed tomorrow so I’m going to string align it and do some test pulls on wastegate. I like how it looks with the wider tires now. Will post some pictures tomorrow.
#54
Just beautiful! Looks mean with the wide stance.
#55
Well done on your build man! The passion you have shows. I’ll need to go back and start from the beginning and reread your whole thread
#56
#57
#58
A one curious cop at honda district car show.
Installed a new switch panel called switchtech the quality is pretty good for like $34 dollars.
Upgrading to 36mm hubs with k-series axles.
Went to do some testings went 11s on wastegate but the trans was hurtin’ and getting locked out of gears.
Went 10s granny shifting and picked up 50mph at the back half. Will be pulling the trans out and putting another set and try again.
#61
What speed or time dictates need for a parachute?
#63
#65
Thanks guys i do have a 10 point rollcage that just sits in my garage, but planning on doing a V2 style detachable chute mount so i can remove it when i driving the streets. Was doing some pulls earlier and my buddy was taking a video so here it is! Don't mind me granny shifting the transmission is on its last legs i think you can hear grind in the video. Anyway, the 26" mickey thompson's hooks good with about half the power but doesn't work so well with the boost controller on.
#66
Cracked the bellhousing on the last track visit.
Also broke the 1/2 shift fork
Transferred the quaife diff to a fresh gsr trans and go for it again.
#69
Yeah it was expected but I’m ready to put some work. This car should be back and making some passes again this weekend.
Had to take the clutch out to change the suspicious rear main seal leak. I didn’t think it was leaking, but i went ahead and changed it anyway.
Throwing this aluminum arm in the garbage and going back to oem lower arm with new energy bushing. Something about it makes me feel kind of funny.
On the process of pressing in the 36mm hubs for k-series axles.
Yep, the car is in 100 pieces at the moment.
Pressed in new pilot bearing as well.
#71
Damn dude, you don't play around with building them OR breaking them!! I guess it's all part of the program. Get 'er done!!
#72
Working on control arms at the moment and might eventually convert it to spherical. Parts cleaners helps a lot and wirewheeling it before paint.
#73
Sorry the attachments are all over the place but got the car back together. Had to timesert one of the exhaust thread on the head and converted everything to arp hardware then swapped the oil pan gasket to felpro as it is thicker and harder material. The oem is to soft and tends to deform and leak when torqued, or maybe it’s just my installation error. Will be making some passes again soon.
#74
If i could get the short track down to low 6s this car should be deep into the 9s. Will try to bring a laptop next time.
Making the kids work for their money. It’s an important lesson in life and gotta start em young.
Anyways, i did some testing today and it was a little sketchy because the oem control arms threw the alignment way off making the car cut so hard to the left and unfortunately hit some cones which pissed off the track officials. I'm a dumbass and should have let off... The gsr transmission seems to be working well just a little short and running out of 4th at 9500rpm with 24.5” slicks so i might have to rev the car to about 10 or 10.5k to fully take advantage of the powerband. Will be getting alignments maybe next week and will try to save this trans for the bigger events.
