jrsc throttle cable 91 crx B16'd
I'm putting in a jrsc into a 91 crx si with a first gen B16, I've searched up and down for an answer and even talked to Jackson Racing and Hasport.
I was wondering if anyone that has done this particular swap, what throttle cable are you using, our current one is about 1.75 inches too long.
thanks in advance for any help.
Re: jrsc throttle cable 91 crx B16'd (dc2b18c1gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2b18c1gsr »</TD></TR><TR><TD CLASS="quote">im not dong this setup, so i dot know.</TD></TR></TABLE>
so why the hell did you reply?
anyways, check my sig for details. i made a bracket so that it would at least be in the right position. however, the wheel size of the throttle body is a little too small, so i never reach full WOT. but its definately enough for it to work right. i've heard the real solution is to use a GSR throttle body.
Re: jrsc throttle cable 91 crx B16'd (keebler65)
i'm using stock integra ls. 90-91 cable
but type r throttlebody.
motorvations told me to get type r throttle cable.. i did.. and returned it because it is the same size at the 90-91 cable.
what cable are you using?
so you guys that have this setup never run WOT because you cant find the right throttle cable. hmm spent alot of money on this setup and I would like it to run to its max pottetial.
I can get it to return to closed and then open maybe 2/3's maybe with the cable that I was using for the B16 swap.
Re: jrsc throttle cable 91 crx B16'd (johnjw)
read my post closer. i said the cable was the right length, but that the wheel that the cable wraps around is too small in diameter. this means you would need a different throttle body, or a larger diameter wheel at the least. also, my TB opens up about 2/3 of the way as well....i guess i dont know how far "WOT" is considered.
have you dynod your car? does it make full power being that the car is only seeing 2/3's throttle?
yeah it dyno'ed at 183WHP which is typical for my fuel management. that doesnt mean that something couldnt be gained by opening it up more though. i plan on making a larger wheel someday when i'm bored.....until then, it will do fine as it is.
my cable opens all the way up and bolts on like stock.
but i have the type r throttlebody. maybe it has a larger wheel than obd0 throttlebodies.
rofl this post made me laugh
Re: jrsc throttle cable 91 crx B16'd (flipsta)
Use a GSR thottle body with the factory bracket then use the GSR thottle cable. It will fit perfect and look clean.
undagroundrican
08-12-2007 07:02 AM
1SIKCRX
07-01-2004 08:06 PM
