JRSC questions...
JRSC questions...
How are they, are they reliable? What other things on top of the kit do you have to do to have it run good and reliably? Its for a ITR....input plz
Re: JRSC questions... (2001TypeR)
I have a 98 ITR. I've put over 20,000 HARD miles on my jrsc with no problems. You will need the high-speed fuel pump, MAP controller, and boost-timing controller to run properly. It gives a great boost in power from the bottom to the top end. Check out the dynocharts at jacksonracing.com. I'm only running 5 psi on a daily driver. If you are building to race and need really high boost then a turbocharger may be the way to go.
