how can you tell if your JRSC belt is too tight?
i just had to tighten my belt more, cuz it was loose and squealing at about 8-9 psi.
but i dont want to over tighten it and snap it, is there any signs or something i should check to make sure its not to tight, it feels about as tight as all my other belts are and seems to be fine at idle Modified by siis2fast at 7:54 PM 5/7/2003 i changed the other post cuz im an idiot, but i didnt want to make a new one, thats way the topic is diffrent than what the title says https://honda-tech.com/forums/images...s/emsmilep.gif Modified by siis2fast at 7:56 PM 5/7/2003 |
Re: how can you tell if your JRSC belt is too tight? (siis2fast)
i've always heard to only tighten it enough to stop the squealing. tightening it too much will cause the components to wear drastically.
