JRSC LS motor build question.
Old 08-02-2006, 06:49 PM
blkb18's Avatar
Default JRSC LS motor build question.
I have searched and it seems 99% of the JRSC topics are for vtec and lsvtec motors. I have a complete LS motor siting in my garage and want to build it for a JRSC. How much boost is possible with the ls kit? Plan on hondata S200. Any piston/rod suggestions?
Old 08-03-2006, 08:53 AM
quis84's Avatar
the ls blower is the smaller m45 like the single cam so you acutally will not be able to make much power with out nitrous the most boost i would run would be 8-9lbs before looking in to there water injection or a lht unit for cooling and for power the highest i have seen on a ls with a jrsc is high 190's with out nitrous but it will be a fun car
Old 08-03-2006, 03:23 PM
sc4dr's Avatar
Default Re: JRSC LS motor build question. (blkb18)
Don't do it unless you can fit an M62 blower on it. The M45 is a waste of time. You'd be much better off with a small ball bearing turbo, and I'm a past owner of a supercharged setup.
Old 08-04-2006, 02:43 PM
blkb18's Avatar
Default Re: JRSC LS motor build question. (sc4dr)
or i can just go ls vtec, all i need is some more low end torque. I race autox and some of the smaller courses kill me, 2nd gear is useless below 4500 rpm. I plan on doing jdm itr final drive swapwhich will help some but will bump me from dsp to street mod class, so i might as well do something with this ls motor thats sitting in my garage since motor mods and swaps are legal in street mod class. Thanks for the info.
honda_mike
08-03-2009 04:09 PM
xXxDelSoulxXx
02-14-2007 10:01 PM
Weapon_R
09-05-2004 01:28 PM
abs0lutexer0
10-28-2003 01:55 PM
Quick Reply: JRSC LS motor build question.
