jrsc b18c build looking for updated info .....
Old 03-05-2010, 07:44 AM
2000gsr-dragon's Avatar
Default jrsc b18c build looking for updated info .....
i have a b18 out of my 2000 gsr, it had suffered a spun rod bearing. that being said ive been collecting parts to do a build .
so far i have
salvageable block- anyone know of a rep machine shop in south broward fla ?
stock 30k mile gsr head
new eagle crank
new eagle rods
jrsc kit aquired
im not sure what brand pistons to go with or C/R at the moment...
what im looking to do is build a dd-jrsc motor. (yes ive been reading new and old threads) but looking for up to date info and suggestions on this build
i drive aprox 40 miles a day in this car pluse my week end run around. my average cruseing speed is 80mph . im not really looking for a race car but id like to have a ballzy car thus thge reason i grabbed up the super charger.
any thoughts would be nice
and machine shop in south broward to clean this block up and make her ready for build would be nice, i have indeed thought about sleeves as well
thanks again...
Old 03-05-2010, 07:46 AM
Default Re: jrsc b18c build looking for updated info .....
i for got to mention i have been reading a bit about useing a b16 intake cam as a exaust cam? on this app anyone ever do this ?
Old 03-06-2010, 03:01 PM
bump?
Old 03-07-2010, 07:07 AM
Gold DA9's Avatar
im going to be watching your thread. good luck with this.
Old 03-07-2010, 07:05 PM
lol yeah, im down to thought , the eagle bottom i ran into are ls. im getting so much reading done atm its head pounding ! do it dont do it lmao i feel like i gotta devil and angel shoulder gremlins chattering ............
now i gotta figure to dump the ls stuff i got and get the stock stroke or just go with what i got....daily driver reliable is my ultimate goal, wasnt thinking about strokeing it out hummmmmmmmmmmm
Old 03-10-2010, 07:34 AM
bump
Old 03-10-2010, 05:23 PM
I CRX I's Avatar
throw the ls bottom end in it! the JRSC will work great with the added torque just double check your compression, from what ive read, 10.5-10.8 compression is usually the sweet spot for the JRCS, ive also heard of the b16 ex. cam trick but have never seen any real facts about it, i do know that the most common power combo is with a gsr intake and type r ex cam tweaked with a set of cam gears. the highest psi recomended with no intercooling is 9. good luck
Old 03-10-2010, 05:57 PM
ok so ls crank, ls rods, ls pistons or are gsr pistons the same ? ive read some post talking about piston pin height differ piston to piston??? or are the b series the same with a stock deck height. sorry for being a noob..
Old 03-12-2010, 02:09 PM
just got my eagle crank out and did a look over and its weight sits about 5.5lbs lighter !
a few pics of the gsr crank (rip) spun bearing and its replacement im going 89mm instead of 95mm i figured a little push for the better tourque pluse i had this already as well as the 95mm i figured id stay mild as far as a stroke. it is a bit over kill to go eagle but i figured do it now while its apart and i can go upgrade crazy later if i choose with a strong bottom. more to come later...
can find pic in my profile page....dont know why they didnt load???
Old 03-20-2010, 09:39 AM
ok so i got a few things together, picked up a complete used gsr head assy thats nice and clean for this build. i did get to save a bit of coin on this head cus im a ebay snipper lol . supose to be 30k miles with everything included but the valve cover and dist.....nice...
the other two pics show the spot where the rod slap happened due to the spun bearing in the #1 hole of the block. im still looking out for a rept machine shop in broward or dade if anyone wants to speak up for one that do good work on hondas.....
Old 03-20-2010, 10:03 AM
figured id post the pics of the crank since i figured out how to do it, kinda cool i saved a bit of weight 5lbs off the bottom will help a little im sure, was goning to go with the lw verse the fw eagle but i didnt want to be weak just incase of future upgrades. eagle claims 1500hp (over rated im sure) with this crank so.... it (shouldnt) break .
forryk
05-02-2011 01:18 PM
Woody.
02-27-2011 06:35 AM
Ricer no 7
12-22-2010 04:15 PM
Pandahatch
01-13-2007 01:32 PM
RuffGsR
11-10-2002 08:06 PM
Quick Reply: jrsc b18c build looking for updated info .....
