Jet-Hot Manifold, Turbine housing, downpipe and dump tube...
New User
Searched and couldn't find much, but anyone Jet Hot Coated the Manifold, DP and turbine housing with the 1300 degree "Sterling" coating?
I saw the thread with the tubular manifold with this coating, and I'm wondering if the 1300 degree coating is high enough considering we run exhaust temps upwards of 1500+ degrees.
I'd rather get the Sterling color, but if I need the 2000+degree coating, I'll go flat black.
Any info?
Any info?
Re: Jet-Hot Manifold, Turbine housing, downpipe and dump tube... (SiR Kid)
they suggest to get the flat black...but its ugly and grainy looking. id still get sterline . i sent them some parts to coat once, they only coated half and returned the rest in a baggy all jumbled up. when i inquired about it they were initially real helpful for a day..after that i havent heard from them. im using hpc coatings from now on
Re: Jet-Hot Manifold, Turbine housing, downpipe and dump tube... (rOby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rOby »</TD></TR><TR><TD CLASS="quote">they suggest to get the flat black...but its ugly and grainy looking. id still get sterline . i sent them some parts to coat once, they only coated half and returned the rest in a baggy all jumbled up. when i inquired about it they were initially real helpful for a day..after that i havent heard from them. im using hpc coatings from now on</TD></TR></TABLE>
These is good to know.
I was about to send out some thinks to JetHot to get coated w/ 2000F coating..
Have anyone dealt w/ HPC before?
I am a bad person
Re: Jet-Hot Manifold, Turbine housing, downpipe and dump tube... (Midwestrider)
i used a local shop called hot shots sterling coat on my mani and rear turbo housing and it hasnt come off off yet and doesnt look like it will either. rear turbo housing was like 75.00 and the manifold was 175.00.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR Kid »</TD></TR><TR><TD CLASS="quote">Searched and couldn't find much, but anyone Jet Hot Coated the Manifold, DP and turbine housing with the 1300 degree "Sterling" coating?
Any info?</TD></TR></TABLE>
SIRKID,
I had all my stuff coated by Jet-Hot using their 2000 degree black coating. This is what they will tell you to get because of the turbo heat that is produced. HEre is a picture:
Now, the stuff will NEVER rust. For the money it cost, I am not sure I would do it again if I needed too. The stuff looks great but like someone else said, it is a flat black color and somewhat grainy.
If you have any othe questions, let me know by either PM or email.
SIRKID,
Re: (siboi18)
Well I had the mani and Turbine housing coated for 2 reason. The 1st is because it traps heat in which Turbo's tend to love and 2nd looks....
Re: (Kutsuju_SLeePER)
I use polydyn coating on most of my engine and turbo parts and love there stuff. If your gonna get your mani or turbine housing coated make sure to get the black as the gold will fade quicker.-pdang
You should ask turbodandee for a pic of his mani as he has the polydyn coating which has lasted quite awhile.
New User
Re: (bambooluv)
I got my turbo about 3 weeks ago, and it's been in the original bag from Precision, and when I took it out today to put the fittings in it for the oil feed, I noticed some light surface rust forming already.
Since the Inline Pro manifold is stainless, I think I'm going to try my hand at polishing it somewhat, and just send the turbine housing for the black treatment to JetHot.
On a side note, I see that the Full Race manifold/turbo is Sterling colored... I wonder if that' s Jet Hot coating, and if it's shown any signs of problems from heat...
ajusaf
05-05-2005 01:49 PM
NyQuiL
Welding / Fabrication
23
11-25-2004 07:55 PM
