Jaco33's Quest: T25-powered D16Z6 to make 220bhp
So I have a d16z6, stock rods and pistons with arp rod bolts, arp headstuds, cometic head gasket, king enigine bearings, stage 2 clutch, 450 injectors and 255 fuel pump and a t25 garrett turbo.I will be tuning it with a hondata s300. I want to make 220 hp on it, will this handle it? |
re: Jaco33's Quest: T25-powered D16Z6 to make 220bhp
Id say not for long because you ll have A LOT of torque to hit 220 with a t25 because youll need quite a lot of boost.
With a bigger turbo yes. |
Forgot to mention its a t25 turbo with a t28 exhaust end |
Will a healthy stock bottom end D16Z motor that has been tuned properly and has sufficient supporting mods support 220whp?...yes.
Re: Jaco33's Quest: T25-powered D16Z6 to make 220bhp
220 to the tyre with that turbo will require at least 14 psi hands down.That will create a ton of torque.
Unless you use a boost by rpm strategy to keep the torque hit smoother id say youll bend a rod fast. Its like 25 lbs max or something turbo. 125 chp -> 220 whp Inevitably that will be very fast 220 horses with that T25 if you do it tho. Still the smallest turbo id try to hit 220 on a D16 is like a 16g or super60 or something. |
Originally Posted by Autoworks
(Post 51641920)
My timing was WAY too advanced and I was evidently in knock territory and didn't realize until it was too late. Destruction occurred in the middle of a WOT pull at about 12 psi. I had driven around with no problem on 6-8 psi, but wanted more. This event prompted my current build and taught me a lot. Bittersweet affair. Lol |
That blown out piston gives me nightmares.. Im sure that 220 whp is attainable, reliable? will totally depend on your setup, after all, we are boosting cast alum after all :D
When i boost my d series, it will be a weak 6-8 psi, just enough to help it get out of its own way (doing a very budget build CRX) . I have owned 2-3 EG's all boosted and each one of them was reliable motor wise until you turned the boost past 1bar, the axles and everything else, tends to start failing/wearing down :) The most I ever made on my EG hatch d16z6 with i think a y58? tranny (i cant remember its been so long since ive been in a honda i cant wait :D) was around 180 WHP, at 10 psi tuned safely, was using a turbo from some DSM at the time, cant honestly remember. Never blew up. 220 is probably attainable, but definitely not reliable. Even if your head-gaskets helping drop your compression a ton, your still cast bottom end :( The tuner matters a huge deal. Hondata is a great unit and you shouldn't have any problems in that dep. Some places can even offer remote tune if you use their wideband/software etc. And this is how I had my BMW tuned, works fantastic. Just depends on goals I suppose! Good Luck and let us know how it goes! |
Originally Posted by LiquidM3
(Post 51645200)
When i boost my d series, it will be a weak 6-8 psi, just enough to help it get out of its own way (doing a very budget build CRX) . I have owned 2-3 EG's all boosted and each one of them was reliable motor wise until you turned the boost past 1bar, the axles and everything else, tends to start failing/wearing down :) The most I ever made on my EG hatch d16z6 with i think a y58? tranny (i cant remember its been so long since ive been in a honda i cant wait :D) was around 180 WHP, at 10 psi tuned safely, was using a turbo from some DSM at the time, cant honestly remember. Never blew up. 220 is probably attainable, but definitely not reliable. Even if your head-gaskets helping drop your compression a ton, your still cast bottom end :( The tuner matters a huge deal. Hondata is a great unit and you shouldn't have any problems in that dep. Some places can even offer remote tune if you use their wideband/software etc. And this is how I had my BMW tuned, works fantastic. Just depends on goals I suppose! Good Luck and let us know how it goes! Remote tune, sure. I am doing that very thing with my current setup. It's turning out beautifully. |
