Jackson Racing Supercharger Help (JRSC)
Hey everyone.
I installed a JRSC on my 95 GSR last weekend and when i started it for the first time it was idling beautifully which i took to be a good sign. Also, no check engine light.
I then soon heard a growl coming from what sounded to be the blower. Ive driven it about 3 miles and the noise doesnt go away. It gets louder the higher up my rpm's go. It almost sounds like a bad bearing.
I called Jackson Racing and they said that a bad bearing is very unlikely so i dont know. Has anyone else ever had this problem before??? Please HELP!!!
Thanks!
Thanks!
Re: Jackson Racing Supercharger Help (debogsr)
https://honda-tech.com/zerothread?id=435635
I just found this topic. I guess this might be what im hearing. but i mean...
This no way sounds like it should be normal.
Ive never heard another JRSC in action so i guess i wouldnt know
Bump. Boost guage is reading perfect numbers. Could there not be any oil in my supercharger???????
sure its not just ur belts or the idler/tensioner pullies?
Something could be too loose or too tight,
or out of alignment.
does the nose of the supurcharger leak any oil?
(like where the supercharger pulley attaches)
Re: Jackson Racing Supercharger Help (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">sure its not just ur belts or the idler/tensioner pullies?
(like where the supercharger pulley attaches)</TD></TR></TABLE>
Thanks for the reply. I will check the nose tonight and double check the belts/tensioner pullies. I have class till 8 but ill post up the results from when i do that. Thanks again Tad.
HatchbackSqueegee
02-15-2012 04:57 PM
acura, bad, bearing, bearings, gsr, jackson, jrsc, oil, racing, replacement, signs, supercharger, supurcharger, tensioner
