Issue with turbo placement and front motor mount
Old 01-28-2009, 10:33 AM
es_squared's Avatar
Default Issue with turbo placement and front motor mount
So I go to fit my turbo on to see exactly where its touching and its actually touching the top right bolt on the front motor mount. People said to get the ESP traction bar with the torque dampener but getting the ESP traction bar wont help, in fact looking at the images it may make it more difficult unfortunately.
I may cut some of the mount bracket to make space for the oil drain but I was thinking of 3 things for the turbo placement/bolt issue. 1) Taking that bolt off and running with only the other 2 bolts on the front motor mount to see if it clears, 2) Trying to find a spacer to go in between the turbo and the exh mani , or 3) modifying the exh mani itself by maybe angling the outlet to the turbo.
Input/Advice ? This *should* be the last hurdle on the whole build
Old 01-29-2009, 10:57 AM
es_squared's Avatar
Default Re: Issue with turbo placement and front motor mount
Anyone ?
Old 01-29-2009, 01:01 PM
boosted ej8's Avatar
maybe get a clocking flange? have you tried mounting the turbo the other way also
I'm not sure I would run less bolts in my motor mounts
you could maybe run a thicker exhaust manifold gasket as well?
Old 01-29-2009, 04:46 PM
es_squared's Avatar
Hmm good ideas.. a clocking flange eh? Searched on that but couldn't find anything about it, what is it exactly?
Old 01-29-2009, 09:51 PM
http://www.team-integra.net/sections...ArticleID=1146
you can do it like that
or I have seen flanges that rotate the turbo so they can clear the manifold on a top mount
Old 01-29-2009, 10:17 PM
es_squared's Avatar
Ah I've already clocked it, you said 'clocking flange', i thought you were talking about some crazy flange with a pivot or something hehe
Old 01-29-2009, 10:45 PM
well the clocking flange does exactly that
and in my previous post I mean clear the valve cover/head if your running a top mount
I know the panducky shop used it on their CRX but since they shut down their website is gone and I can not find the picture to save my life
Ill check for you
Old 01-29-2009, 10:56 PM
I guess they custom made this
Might restrict your flow a few cfm but if it means fitment or not Its a sacrifice that would be worth it
Old 01-30-2009, 07:41 AM
es_squared's Avatar
Thats ****ing rad, now if only I can find where to get one lol, thanks for the pic man
boostedludesi
06-04-2011 04:18 PM
steve96accord
02-22-2006 10:57 AM
AcCO12D95
08-04-2003 05:55 PM
LxAccOrd95
07-22-2003 08:49 PM
Quick Reply: Issue with turbo placement and front motor mount
