Internals?
Yea I've covered this topic not too long ago but I had some questions about crank/rod compatibility..
motor's an '01 b18b1 that i will be having built for turbo..probably gonna resleeve and go with an 84.5mm bore with arias 9.0:1(or lower) pistons and eagle rods. here's my question, will the eagle rods with with any aftermarket crank, and do you think that i should get a 2.0 crank rather than a 1.8model.. I'm shooting for 500whp with a LOTTA tuning and a LOTTA work for something that's daily driven..just not too far. |
Re: Internals? (cherryhatch00)
if youre gonna bore to 84mm then go with a stroker crank. i would sleeve it 84mm or 83.5mm rather than 84.5mm cuz it doesnt leave you much room to work with if you something goes wrong. i mean you dont even really need a crank imo unless your 500hp is gonna be low boost. i would just micropolish your stock crank and balance it, i wouldnt knife edge it but some people do
well, if i don't go with a different crank then..
does anyone know of any inherent problems the gsr crank can throw at the motor ..or is it pretty solid? |
Re: (cherryhatch00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cherryhatch00 »</TD></TR><TR><TD CLASS="quote">well, if i don't go with a different crank then..
does anyone know of any inherent problems the gsr crank can throw at the motor ..or is it pretty solid?</TD></TR></TABLE> the stock gsr crank can handle waaay more than your going to be throwing at it. i would not go above 84mm bore for the same reasons said above. do you have the ls crank from the engine? with an 84mm bore is pretty close to 2.0 |
the 2.0l crank is the same as your b18b crank
89mm Unless you want to use a 95mm crank with i wouldnt recommend using. do a 83x89 or 84x89 set up |
No, I have no LS crank. It's a bare block I got pretty cheap and want to have re-sleeved and setup with an LS-Vtec conversion. Guess I'll stick to 84mm on the sleeving and either a gsr/ls crank. Whichever pokes it's head up at me first.
| All times are GMT -8. The time now is 02:48 AM. |
