innovative dual ball bearing t60-1....questions
i read that this was a great turbo....and expensive...but what i want to know if will it be good for a stock gsr setup as of now?...i know the dual bearing should make it spool faster than a normal turbo...i didnt see any info when i searched for this exact turbo...anyone running it?
pretty big turbo u planning on running... i wouldnt recommend it on a stock setup since you won't be able to run a high amount of psi. id figure it'd take pretty long to spool up at 6-8 psi. my buddies got a t60-1 running 14 psi on a fully built engine. he's making 420 whp and reaches full boost at around 5000-5500.
Re: innovative dual ball bearing t60-1....questions (cmGSR916)
i just sold mine-- for street driving (monster on highway though)
switched to a sc34 and loving it...
Re: innovative dual ball bearing t60-1....questions (turboEGhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGhatch »</TD></TR><TR><TD CLASS="quote">Ball bearings are overrated. Not worth the cost.</TD></TR></TABLE>
opinions are like ********....everyones got one
Re: innovative dual ball bearing t60-1....questions (B18 CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18 CYA »</TD></TR><TR><TD CLASS="quote">
opinions are like ********....everyones got one</TD></TR></TABLE>
"A sucker's born every minute"
If you feel the 200-300 odd RPM's you pick up in quicker spool is worth 900 dollars, go right ahead and buy them
