Innovate LC-1 issues... Confused
So i decided to try the Innovate LC-1 wide band ( usually a plx guy) installed the unit per the instructions and did the free air cal. and the heater cal. Well the issues i am running into are 1: the sensor reading on the gauge reads 22+ full lean and its not lean.. 2: when i turn on the key let it warm up it sits around 9.9 and reads nothing. anyone had this problem before. Do i have to get in to the firmware and calibrate something or these systems junk?!
Thanks
Russ
Thanks
Russ
Re: Innovate LC-1 issues... Confused
try hooking up the lc-1 to a laptop using the serial cable. If its a ground offset issue it shouldn't affect the serial output.
ground for sure. i just set my lc1 up a week ago. Yea the aem one is easier to setup no calibrating and it doesnt matter where its grounded. My readings on the LC1 seem to bounce around alot more than with the aem one i had.
85_305
16
02-04-2009 04:12 PM
4g4db16
10
10-13-2007 01:50 AM
