which injectors for this setup?
fully built b16
revhard turbo kit hondata s200w/boost I want to run 15lbs daily and reliably. 550? 780? saturated? etc,, what are you guys using? |
Re: which injectors for this setup? (XX Boosted Si XX)
At the least 780's depends what your hp goals are.
780's would be good enough for your power goals. Not sure if there is a company that makes saturated injectors in 780's but if there is go with saturated.
Re: which injectors for this setup? (airshifta)
I believe rc now makes a 750cc saturated injector.
