Injectors on my set-up LMK??
I have a B16A in my 94 Civic, the Turbo I am going to be using it the Mitsu t25. I am thinking of using the RC310cc injectors. I want to know if this is going to be over kill?
I also need to know when I put the turbo on can I start it with the stock injectors, this way I don't have all that fuel going in and no way to control it? I have a Hondata ECU now, witch I hope is good enough........
Last thing, I know the T25 suck, but it's what I have for now and it's only till I get the motor up to take something BIG. It is a daily driver and I need it to be a good running car.
Thanks for any help........
Re: Injectors on my set-up LMK?? (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE »</TD></TR><TR><TD CLASS="quote"> I am thinking of using the RC310cc injectors. I want to know if this is going to be over kill? </TD></TR></TABLE>
nope that's under kill. you'll want bigger.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE »</TD></TR><TR><TD CLASS="quote">I also need to know when I put the turbo on can I start it with the stock injectors, this way I don't have all that fuel going in and no way to control it? </TD></TR></TABLE>
can you start it? sure! can you drive it? well technically yes but don't do it. install your bigger injectors and hondata setup and tow it to a tuner.
Ok, so the injectors are not gonna be got enough.......
Now it's only a t25, the kid I am getting them from had them on a greddy turbo.
So I can start the car with the stock injectors just to make sure every thing is ok, but don't drive it right? The Hondata is already in it.
Re: (CBURKE)
is the hondata calibrated for stock injectors or aftermarket? if stock, yep, you should be able to start it just fine to make sure your setup is ok. I would not drive it at all.
