Injector coating at nozzle cracked off!! What should I do!!!
Ok, I just picked up a set of rx7 Injectors, for a fairly great price. Later on the day, for some reason the coating around the (nozzle?) The lower tip where the fuel sprays into the motor. The coating chipped off! The spray tip is still ok though.
Now with 4 Injectors, with one chipped. What should I do? I am awake that these ends comewhat controls the spray angle?
What should I DO!! HElP!! Run them still with one fuct up? or Chip off all four coatings? or Glue the chip coating back on? !!
And yes, money is a Factor. I know I need to get New injectors. BUT IM POOR! Help for now. Just to get my boost runnning. Thanks!
:::::::::::UPDATE - ADDED PICS :::::::::::::
Modified by synik at 10:56 PM 6/23/2004
Modified by synik at 10:57 PM 6/23/2004
Re: Injector coating at nozzle cracked off!! What should I do!!! (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik »</TD></TR><TR><TD CLASS="quote">. I know I need to get New injectors. BUT IM POOR! </TD></TR></TABLE>
having a turbo car and being poor dont mix well bro.. i know first hand, its always good to have some extra money layin around incase something happens to the car..
im sorry bro.. i dont know what to tell you bout the injectors tho, does it sit properly in the fuel rail and IM?? if so i would just try it see how it goes..
Re: Injector coating at nozzle cracked off!! What should I do!!! (TurboBumblBee)
when i had my ls turbo motor, i was using an injector like that for awhile. don't even know how long. just realized it was broken off when i put the rc 310cc injectors in. i didn't have any problems with it.
If you are talking about the plastic cap that is below the lower o-ring, it's called the pintle cap. It's function is to hold the o-ring in place and (depending on the injector style) protect the pintle from damage. In most cases you can get away without it as long as the manifold won't allow the o-ring to fall in the intake.
Gordon
WitchHunter Performance
http://www.witchhunter.com
Gordon
Re: Injector coating at nozzle cracked off!! What should I do!!! (switch)
Hmm, I really don't know what to do.
The part the was cracked off was the outer layer of the lower nozzle. (stock honda, the color is Orange?) at least on my gsr it was.
Wouldn't removing that cap affect spray? ?
TurboBumblBee- Trust me bro. Having turbo is addicting. Once your eyes and mind get hooked onto it. You will definately starve. -=P Being on a tight budget as I am. I am barely having enough to finish off my kit. Thats why im on a tight budget, to actually spend a tiny bit more to complete this and get it over with.
HELP! Should I crack all 4 off? and run it? THanks.
Re: Injector coating at nozzle cracked off!! What should I do!!! (evil newgsrdriver)
Just be careful when installing it not to damage that little tip and you should run it.
Dont break any of the others to match.
Re: (feri0)
called a pintle cap...just find a local shop that cleans injectors and they can put a new one on..it should be really cheap..the cap itself it prolly less then $1..nut what what is involved with replacing them but it cant be much
Re: (gritsak)
O_O THANKS SO MUCH!!! PHEW! My Turbo project was thought to be down few weeks, until i get some more money! Lots of shops told me, that Im Fuct~
BUt, how is it possible to replace? Does it unscrew? -=P Thanks so much tho guys. Appreciate it.
TURBO HERE I COME!!!!!
Re: (synik)
im not sure how they replace them, but im positive you can...i have a set of denso 720's on my car right now that all the pintle caps were broken and i got them all replaced when my injectors were cleaned...maybe they attach with some special adhesive/glue?
Re: (chad174)
hMm, good to know this. -=P I need to find a place to actually do that here in albq. Kind of hard. -=P Thanks again for the reassurance.
Kenny,
Just run it bro. YOU NEED TO GET THAT DAMN THING RUNNING!!!!!!
I would run them as alot of people have stated in here.
and you are right......albuquerque does suck!!
Jon
Jon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik »</TD></TR><TR><TD CLASS="quote">:::::::::::UPDATE - ADDED PICS :::::::::::::
HELP! Should I crack all 4 off? and run it? THanks.</TD></TR></TABLE>
run it, but don't crack all 4!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evil newgsrdriver »</TD></TR><TR><TD CLASS="quote">A broken pintile cap should not affect flow...its for protection. I would run it.</TD></TR></TABLE>
Agreed. Great new user pic btw Nick.
The pintle caps on these injectors do not have anything to do with the spray pattern. With some other types, they do direct the fuel.
Gordon
Gordon
I broke mine on my dsm 450s, so I completely broke it off and it works fine. I talked with a professional mechanic and he said it was just for protection. One year already and no problems. I did this on one injector only.
Re: Injector coating at nozzle cracked off!! What should I do!!! (DaX)
Haha thanks man...about time someone knows who Andrew WK is!
Since switch brought it up, what kind of injectors utilize a pintile cap that affects spray pattern?
i'm running 450's with one of the injectors missing the cap. It should be fine.
Re: Injector coating at nozzle cracked off!! What should I do!!! (SOHC_MShue)
i had one crack right there ... may have been more than just right there ... but it wasnt running the injector correct after that .. kept saying i was running rich ...put another injector in ... no probs since
