injector battery offset for RC650 saturated
anyone has values for these saturated 650 cc injectors in crome free v1.5????
the battery offset in the advanced table in the drop down (more) menu seems too low.. i increased them by 2 points (e.g 0.60 is 2.60) and that made the motor start right up with AFR's in the 13-14.. but it wont rev .. as soon as i give it gas (in neutral) it stutters and the rpms wont climb up and the wideband starts to read 25+ AFRS.
i need to add 600 to the whole map starting from the 5th column all the way to 11.3 psi column to make it rev freely in neutral. but it goes lean while am driving in gear..
any comments??
btw the car was running perfect on stock injectors and crome with the p30 code.
any comments??
