ignition timing
i have a d15z1 in my del sol
maybe this is becouse its economy model or someone may have used wrong distributor. but my fullly advanced distributor my timing light reads that its set to 14 degrees. any body got thoughts on this? i want to get to at least 16 degrees, the only thing i can think of doing is grinding the holes of my current distrib so i can get that extra 2 degrees |
Re: ignition timing
How are you timing it? Are you waiting for it to warm up? Have you tried unplugging your IACV to see if you can get the idle down to around 600 before timing it?
Re: ignition timing
Originally Posted by Eran
(Post 43176597)
Re: ignition timing
I'm not saying you don't have the wrong distributor, but as far as I know, they're all pretty much interchangeable for OBD1 d-series. Without knowing more about your setup, I couldn't judge.
Are you using the stock ECU, or is it chipped? |
Re: ignition timing
(Post 43176787)
Re: ignition timing
Ah, well like I said, I wasn't sure the in's and out's of your setup. I assumed you had at least had a VTEC dizzy, but I could have been incorrect. Did you piece your swap together, or did you just get a longblock and salvage parts off your D15B7?
Re: ignition timing
(Post 43177159)
but anyway my car wont idle without the iacv.....my car is at about 850 rpm and timing light showing about 12 degrees on the crank i am starting to think my t belt is 1 tooth off http://i106.photobucket.com/albums/m...7-31003525.jpg |
| All times are GMT -8. The time now is 05:23 AM. |
