Idle Curiousity - Anyone Know the Actual Dimensions of the FK8 TD04 Turbo?
Haven't seen this listed anywhere and I'm definitely not in a position of being able to figure this out by measuring one on my own.
I know the turbo is a "Single Scroll MHI TD04", but does anyone know the actual wheel dimensions on the compressor/exhaust wheel? I'm assuming something around 40-44mm on the exducer on the hot side, 45-50mm on the inducer. Maybe 45-50mm on the compressor inducer, 54-58mm on the exducer.
But this is just random *** guessing, curious if anyone has actually measured one of these.
Re: Idle Curiousity - Anyone Know the Actual Dimensions of the FK8 TD04 Turbo?
2017-2018 Honda Civic Type R Turbo Review of Specs / R&D / Development + More!
https://www.civicx.com/threads/anyon...e-turbo.12716/
Supposedly a TD04 running at 23PSI.
Judging from the power the FK8 Type R is able to produce (~380whp) it has to be a TD04HL variant with a 18T, 19T or 20T compressor wheel. FYI McLaren use a similar turbo in twin's configuration for their 3.8 litre V8 (1.9 litre per turbo). Direct Injection, VTEC and high compression undoubtedly help extract every last horsepower from the limited lb/min flow.
Moderator
380whp?. mmmm. possibly., But even the 18T's never got to that level, even if they prayed. I'll give you a Mitsu chart so that you'll know what I'm referring to. Even at the 18T's best choke point, that's about 38lbs/min. That's enough to do 350whp, but at over 2.5PR, (that's over 36psi of boost pressure). I doubt that the R is running that much boost to do that. 16-22psi, sure.. but not over 36psi..
Here you go. I'm not saying you're really wrong, I'm just saying.. check your source and make sure that you're talking power to the wheels , not Brake Horse Power, that's all.
MHI Turbocharger reference chart
Even a 20T couldn't do 380WHP.
I think right about 350WHP has been done by PFI, not sure at how much boost (I think they were still at 23.5PSI). They changed the downpipe.
4Piston Racing also has some parts and head options now for the K20C1 engines, but if you're still limited to the stock turbo manifold or especially the turbo itself, I don't think you'd get much higher than what's already been seen.
pfi dyno has fake numbers at least thats the rumor....they "compensate" for high altitude. they do show uncorrected value but not what correction that they are using.
makes 250 uncorrected. math says there using 1.4 correction but hard to say how accurate this is
They also tuned the K-Swap Hondaru on a third party dyno after the PFI shop location had to close down, with Brent again doing the tuning, and it came out with crazy results. If they're fudging the numbers, it's not by much.
Td04 turbine wheel is much smaller from td05 right?
Im saying if its really a 4646 sized turbo it would work TOO hard for that 322 hp of the type r. Not for the number achibed but for the reliability of the turbo... Just saying.
In the video I linked above they also mentioned that the turbo has no special bells and whistles. Still a cast compressor wheel. 23.5PSI is pretty high for a factory car, and would be on the upper limit of the usable threshold on the turbo, but the power outputs still seem pretty impressive for what's going on.
I'm assuming having 2.0L of displacement and (I'm assuming) an efficient cylinder head with almost 11:1 compression is helping as well.
Moderator
Their dyno is legitimate. Kyle from Boostedboiz has dyno'd his Civic on the PFI dyno and then within a week on a different dyno without changing anything, and his WHP results were within like 1-3 WHP of one another. Brent tuned Garrett/Cletus McFarland's 1200+WHP shelled Corvette recently as well just doing a road tune and the results were impressive (no dyno numbers to compare it with, but that's a pretty high standard to work with and be successful with for on the fly road tuning at elevation).
I think that we need to know simple SAE correction. that's always been the standard of measurement accounting for as many factors as the sensors deem available.
Agreed, but so far I haven't heard of too many premature failures on these turbos. Again, I'm very interested as to what the actual size is.
The 11:1 compression helps with the engine being to get to the correct dynamic compression more quickly, but it doesn't change the amount of boost pressure by that much to the point of where a turbo of this general size wouldn't still already be within it's CFM choke point, and change numbers significantly. So, we'll need to see when folks get their hands on them.
As stupid as it may seem to us enthusiasts here, many that do have possession of cores are keeping measurements under wraps until they can create an upgrade for release to those that can afford the platform upgrade. We have a general idea of what needs to be increased, and most will just put out a bigger turbocharger and either adapt it to work within the "headifold" as the original, or create something that uses the same housing configurations.. Time will tell.
per the video it made 250 uncorrected anything past that is speculation at best. As it's been said hundreds of times the dyno is just a tool hard to say exact numbers once correction comes into play
And how do you know the "third party" was not using correction? Just say in
Off topic anyway. Apparently the exact specs of these turbos as of yet are unknown/unpublished.
Like everyone is saying, it's just numbers. All I'm trying to point out is I don't believe PFI to be a shop that feels necessary to pad their numbers in order to appeal more to customers.
I've only had 2 in my possession briefly, and couldn't measure wheels from them at the time. One was for a 10th Gen SI, the other for the FK8 Type R. I'll see if I can get them back to get some photos, or something.
DelSolMike
03-09-2007 08:30 AM
boosted-EG6
11-12-2005 09:46 PM
