Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Identify this turbo & hot side options (https://honda-tech.com/forums/forced-induction-16/identify-turbo-hot-side-options-2915589/)
luv2boost Mar 27, 2011 09:32 AM
Hello. Just picked up a turbo from a buddy and have few questions. What kind of turbo is it? Who manufactures it? What are my options for a hot side to get 300-350hp & quick spool?
The only markings are pictured:
Inside the charge opening is marked .70
Cast into the housing is A/R 70 M24
Exhaust wheel measures approx. 2-3/4" diameter
Any help to identify this turbo is appreciated! Also if you have hot side that I can mate it up with LMK. Thanks!
http://i192.photobucket.com/albums/z...r98/Turbo1.jpg
http://i192.photobucket.com/albums/z...r98/Turbo2.jpg
http://i192.photobucket.com/albums/z...r98/Turbo3.jpg
http://i192.photobucket.com/albums/z...r98/Turbo4.jpg
luv2boost Mar 28, 2011 07:15 AM
Re: Identify this turbo & hot side options
Gotta be someone who knows more....
96 GSR-T Mar 28, 2011 09:03 AM
Looks like an 11 Blade Turbine Wheel, kind of like a P-Trim but it seems smaller from the measurements, without measuring the comp wheel there is not much we can tell you other than what you have already told us lol
Im gonna take wild guess, maybe its a 60-1 or a GT35, then again that comp wheel is around 50mm??
luv2boost Mar 28, 2011 03:51 PM
Thanks for guiding me a little bit. Got a hold of some digital calipers, took the compressor housing off, and got some measurements:
Compressor wheel (intake)-
Inducer: 57.7mm/2.27"
Exducer: 75.9mm/2.99"
Turbine wheel (exhaust)-
Inducer: 73.4mm/2.89"
Exducer: 63.8mm/2.51"
96 GSR-T Mar 28, 2011 04:07 PM
Here are the specs on a P-Trim Turbine....
Inducer 2.920" (74mm) Exducer 2.542" (64.5mm), I would have to say they are the same.
58mm Comp wheel.... it should make 500ish hp I would imagine... not really sure what it is, im going to guess a T4 60-1 or a little smaller, not sure what size the comp wheel is on a 60-1 but I am pretty sure its smaller than 60mm and you can get it with a p-trim turbine.
Also that looks like a Garrett Comp Housing.
luv2boost Mar 28, 2011 04:41 PM
Thanks! Good to know. So I should be looking for a p-trim turbine housing or is there different options? I only plan on tuning to ~350hp & would like it to spool quickly.
96 GSR-T Mar 28, 2011 06:27 PM
I would say so, the numbers arent exact but neither are dial calipers. You can get a housing for that wheel in a T3 or a T4.
luv2boost May 2, 2011 08:47 AM
Picked up a .96 turbine housing. Here's a pic-
http://i192.photobucket.com/albums/z...fattyturbo.jpg
From what this thread is saying, this setup is gonna be a slug on the street & not get full boost by 7k-
https://honda-tech.com/forums/forced-induction-16/anyone-running-96-r-t4-street-car-2611760/
But then there's this thread saying a t4/t67 .96 turbine won't be laggy on the street-
https://honda-tech.com/forums/forced-induction-16/t4-t67-96-turbine-too-big-2487111/
As of now i'm only looking to tune for ~350 hp as a daily driver. Any experience with a p-trim or similar setup with a .96 turbine housing? Should I run a smaller turbine housing such as a .61, .70, or .81? I don't want it to take days to spool up.
TheShodan May 2, 2011 08:51 AM
A T4 .58A/R is about as good as its going to get with a P-trim exhaust wheel of that diameter size.
luv2boost May 2, 2011 09:16 AM
Thx Shodan! Two closest options on atpturbo.com for the t4 p-trim are ".61 undivided" or "Alternate On Center .58 A/R Housing with round 4 bolt out".
http://www.atpturbo.com/mm5/merchant...egory_Code=GTH
Is the second .58 a/r "Alternate On Center" setup the optimum turbine housing or the .61?
Not sure what alternate on center means.
Or is there a better place to find a T4 .58A/R turbine housing?
TheShodan May 2, 2011 11:25 AM
You've found it. The "On center" housing puts the turbine in a different spot. Most people on this forum are use to the "tangential" housings.
On Center Housing
http://www.vmsperformance.com/catalo...39-0-large.jpg
Tangential Housing
http://www.atpturbo.com/mm5/graphics...SG-016_450.jpg
vtechjunkie May 2, 2011 06:52 PM
So then which is better? The "on center" or the "tangential"?
TheShodan May 2, 2011 08:09 PM
There's no better. its about what fits. if you had a Tangential before, just use one again.
wantboost May 2, 2011 09:50 PM
you can find a tangential .58 t4... look on ebay, atpturbo isnt the end all be all of turbo stuff.
not to mention, on a b16 that thing is going to be incredibly lazy
E85B18 May 3, 2011 07:52 AM
At what rpm do you think this set up will hit 350whp?
TheShodan May 3, 2011 09:14 AM
No one can really answer that one. that's a boost/rpm curve question
Stopsign32v May 24, 2022 09:58 AM
What is the exhaust setup?
TheShodan May 25, 2022 06:49 AM
10 years? You sure about getting an answer in this, chief?
Stopsign32v May 25, 2022 08:59 AM
I don't know how this reply got to this thread. The exhaust question was directed towards your Project Ghost thread.
Ryanthegreat1 May 25, 2022 07:57 PM
Probably because mobile version of this forum sucks and if you scroll down beyond the last post of the thread you are viewing it jumps to some random ass old thread with really no indication.
