ID these Injectors please, searched
got these off of Ebay, the auction said they were RC 550' high imp. Which clips can i use for these? DSM clips? RC injector clips? I drive a 96 LS, i tried the stock clips and there was no way they were going to fit. can I use the clips off of importparts.com? I searched but there were no good posts showing the different clip patterns.... thanx!
URL=http://i15.imagethrust.com/p/37415/whichclip_jpg.html][/URL]
[img=http://i15.imagethrust.com/t/37415/whichclip.jpg]
URL=http://www.imagethrust.com][/URL]
Re: ID these Injectors please, searched (Ftrceo)
Last time I checked, RC's do not have a pink plug. Also RC's injectors actually say "RC" on the side of them. I can't really make it out in the picture but it doesn't look like it says RC in red letters on the side....sooo I am going to lean toward those are definitely no RC 550's. I would also post a better picture. Post the profile of the injector and not just the clip plugin part.
The plug does look like the clips that you can use off of importparts.com though.
Re: ID these Injectors please, searched (Dunc)
the top part is more of a dark raspberry color, the lighting was off on my camera phone. It says denso on the side of it , the guy said he used them on his eclipse. I will get the part # tonight. does denso make a 550cc high imp injector?
thanx for any help!
Ftrceo
thanx for any help!
Ftrceo
ok, the real question now is "Which clips to use for Denso Injectors?" i think these are the 550cc High imp DENSO injectors. which clips and where can i get them?
thanx!,
ftrceo
thanx!,
ftrceo
those look a lot like 550cc RX7 injectors if I remember right. Not 100% positive - been a while. You could probably razor them and use OBD0 clips from the look of it. I'd get them flowed by RC or someone to make sure they are indeed 550s and not the more common 460cc RX7 denso injectors.
Re: (blundar)
http://www.witchhunter.com/Flo...d.jpg
ok i figured them out, I guess reading the part #s on the injectors really helps to identify them. (*slaps forehead*) looks to be high imp 550cc. now if I could just figure out what clips to use...
88 13b T high square offset 550cc purple 195500-1370
Mazda RX7 injectors..... off to the junkyard I go!!!!
actually you might be able to use some toyota clips on those my friend has those injectors on his car. we got him some clips from a tercel and some other kind of toyota i forget at the junkyard
1990-'93 Geo Storm 2+2 & Stylus S Saturated 222cc
1990-'93 Isuzu Impulse & Stylus XS Peak and Hold 222cc
1991-'92 Isuzu Impulse RS AWD Peak and Hold 322cc
1988-'91 Civic Si/CRX Si Peak and Hold 240cc
1992-'95 Civic Saturated 240cc
1996-'00 Civic dx cx and lx Saturated 190cc
1996-'00 Civic ex/si Saturated 240cc
1990-'91 Integra RS/LS/GS Peak and Hold 240cc
1992-'00 Integra LS/GS Saturated 240cc
1992-'96 Prelude Non-VTEC Peak and Hold 240cc
1992-'96 Prelude VTEC Peak and Hold 345cc
1997-up Prelude VTEC H22 Saturated 280cc
1991-up Sentra SE-R/200SX SE-R Saturated 265cc
1991-up MR2 Turbo Peak and Hold 440cc
1988-'91 Supra Turbo Peak and Hold 550cc
1993-up Supra non-Turbo Saturated 315cc
1993-up Supra Twin-Turbo Peak and Hold 550cc
2000-up Celica GT-S Saturated 310cc
1990-up Miata 1.6-liter Saturated 215cc
1993-up Miata 1.8-liter Saturated 240cc
1984-85 RX-7 195500-0900 Peak and Hold 680cc Orange Top
1986-87 RX-7 195500-1350 Peak and Hold 460cc Red Top
1986-87 RX-7 195500-1370 Peak and Hold 550cc Tan Top
1988 RX-7 195500-1350 Saturated 460cc Purple Top
<U>1988 RX-7 195500-1370 Saturated 550cc Purple Top </U>
1989-91 RX-7 195500-2010 Saturated 460cc Red Top
<U>1989-91 RX-7 195500-2020 Saturated 550cc Purple Top </U>
1993-up RX-7 Twin-Turbo Saturated Primary 550cc Secondary 850cc
1990-'96 300ZX Twin-Turbo Saturated 370cc
1991-up 3000GT VR-4 Peak and Hold 350cc
1989-up Eclipse/Laser/Talon Turbo/non-turbo Peak and Hold 450cc Blue Top(95+ Black top)
390cc Tan top
240cc Orange/pink Top
210cc Light Tan Top
Mitsubishi EVO Peak and Hold 510cc Yellow Top (1-3)
560cc Red top (4+)
1986-89 Ford turboCoupe Peak and Hold 35lb/hr Brown Top
30lb/hr Green Top
I bolded the pruple ones,
there ya go,
390cc Tan top
210cc Light Tan Top
560cc Red top (4+)
30lb/hr Green Top
there ya go,
Look like RX7 460's... I used them before. Heres a writeup i did on them (you CAN use OBD0 or OBD1 plugs):
https://honda-tech.com/zerothread?id=730383
Heres a comparison of size differences here (from left to right)
OEM - DSM 450's - RX7 460's
Re: (T-RO)
im gonna shave these babys down and see if I can get them to fit the stock harness, if not it is off to look into some early 90s Tercels and Corollas. I have read that their injector plugs are the same. Thanx for all the help guys!!!
superduperman
09-13-2003 12:37 AM
