I think my AVC-R is dieing on me?
We'll last week it was working fine. I would keep it on the screen where it would show boost, rev, and throttle.....numericly. Then I noticed the boost numbers would stop. When I nudge the AVC-R around it would start up agin. Now none of those options work. The AVC-R turns on and goes to that screen but everything is at zero! Has this happened to anyoune before?
Thank's David!
Thank's David!
Re: I think my AVC-R is dieing on me? (turbo Si)
sorry, this is an old as post, but the answer is so simple.
When you press up, the values stay at maximum. When you press down they go to real time numbers. The reason why boost said zero is because it was keeping the values when the car was off. (I might have got the up/down backwards, but you get the idea).
If you use the 2var logging mod with the peak value and the current showing, pressing right will clear the peak value and hold the current peak value. I don't know if this is in the manual, but you can figure it out by pressing buttons.
[Modified by TypeC, 2:28 PM 7/12/2002]
delslo93
08-15-2006 04:50 PM
LudEcrous
09-08-2004 08:21 AM
