I NEEED HELP PLEASE....... TURBO DOING REALLY WEIRD THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
alright i have jdm b16 with a t3/to4e turbo... iam running 440cc injectors, stock cx radiator and heat wrap only on the intercooler piping that goes under the downpipe... my car is tuned with hondata s200b ..setting are low=7psi and high=10psi.... now i dont know if its somehting to do with heating problem but my problem is when i run 7psi car runs great no problems.... when i run 10psi i can do couple good pulls then when i get on it again after 6grand (gsr cams vtec comes in, that what it wwas set at ) like the car makes a weird noise and struggle kinda to 8200.... like it almost sound like fuel cut off like aspuder and does it repeatily... iam just wondering if its something to do with not proper cooling of turbo or what .... cuz it ddoesnt do it on 7psi and the car was tuned 3 weeks ago at payne technologies????? any help would be awasome
Re: I NEEED HELP PLEASE....... TURBO DOING REALLY WEIRD THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! (Ju
im gonna say most likely spark issues.
sounds like the spark is being blown out.
get some bkr7e's and gap them to .030. hth
sounds like spark to me as well.
from alot of people who tuned at payne, assuming thier motors didn't blow, they say they are having some ignition troubles
Moderator
Strange. Same thing happened to one of my rides with my s200b. It only happens every once in a while. It'll sputter like theres a ton of fuel in there, even though it was tuned at another location other than Payne .. Ran like a champ last week. I'm wondering if coolant enrichment is messing with the timing. New Bk7s are already in there.. But I feel better knowing I'm not the only one
Re: (TheShodan)
yea it will only do it occasionally... like if i pull over n let car sit and cool for alil then i can do more runs on 10psi... iam guna try spark plugs today... then iam guna upgrade radiators nexta dn mroe heat wrap!!!! any more input will be thanked till problem solved
Re: (JusT a Cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JusT a Cx »</TD></TR><TR><TD CLASS="quote">yea it will only do it occasionally... like if i pull over n let car sit and cool for alil then i can do more runs on 10psi... iam guna try spark plugs today... then iam guna upgrade radiators nexta dn mroe heat wrap!!!! any more input will be thanked till problem solved </TD></TR></TABLE>
Why do you think it has ANYTHING to do with heat wrap or the radiator.
Its obvously something with the tune or the plugs.
GsrIntegra789
06-14-2008 09:14 AM
2LiterTurboSeR
03-18-2006 03:11 PM
