I need some help with my new setup!
99 Turbo Civic SI .......Blown! Need help with new install!
I have a 99 si turbo... I blew my ring lands and my car is a locomotive on 3 cyl so Im taking everything out...
I was running 440cc w/ a vafc before..
Here is what I am doing now...(sorry I am a noob w/ FI Hondas). But, I am curious if I am missing anything and what kind of boost and Hp this setup will take (w/ a good tune of course )
I am replacing the pistons with weisco 8.8 :1
I am also changing to ACL bearings
The afc is coming out and I am putting in a Hondata S200 and adding cam gears
New street/strip ACT and fidanza flywheel
My other questions are regarding:
Head gasket? Head studs? block guard? or anything else you guys have for me..
Thanks
Modified by InDub at 9:47 PM 8/24/2005
Modified by InDub at 9:48 PM 8/24/2005
Thanks
Re: 99 Turbo Civic SI .......Blown! Need help with new install! (InDub)
Headgasket: Stock/Golden Eagle
Studs: ARP/Golden Eagle studs
Guard: Darton/Golden Eagle sleeves
Do it right.
Jason
Do it right.
Jason
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InDub »</TD></TR><TR><TD CLASS="quote">
I also have a B16 running JE pistons 8.8:1cr, eagle rods, oem head gasket and I reused my stock head bolts (I would have gone with ARP but they were 2 months back order and I needed the car out of the shop). But I haven't had any problems 334hp & 246tq
Re: 99 Turbo Civic SI .......Blown! Need help with new install! (yehiknowrite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite »</TD></TR><TR><TD CLASS="quote">wont the 8.1's cause a loss of power before boost kicks in?</TD></TR></TABLE>
he's going with 8.8:1cr not 8:1cr.
Re: 99 Turbo Civic SI .......Blown! Need help with new install! (SFWD 1934)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SFWD 1934 »</TD></TR><TR><TD CLASS="quote">Headgasket: Stock/Golden Eagle
Do it right.
Jason</TD></TR></TABLE>
For the Guard... Is that just a block guard or is that actually having the block sleeved?? Since I know that is my limitation is the sleeves..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">
I also have a B16 running JE pistons 8.8:1cr, eagle rods, oem head gasket and I reused my stock head bolts (I would have gone with ARP but they were 2 months back order and I needed the car out of the shop). But I haven't had any problems 334hp & 246tq </TD></TR></TABLE>
I wasnt going to do rods, becuase I heard they were not necessary unless I was sleeving the block, the stock rods should hold up to 15psi or 300whp??
How much boost are you running and what did you use to tune it?
Do it right.
You will already have the block out i'd suggest you do rods also...If you look around you can get a good deal, i sold my eagle rods with 800miles on them for 215$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InDub »</TD></TR><TR><TD CLASS="quote">For the Guard... Is that just a block guard or is that actually having the block sleeved?? Since I know that is my limitation is the sleeves..
How much boost are you running and what did you use to tune it?</TD></TR></TABLE>
NO, blockguards are worthless IMO, the stock rods will do 300whp tuned correctly ya, but so will the stock pistons.
16-17psi using AEM EMS.
Re: (Sick00SiCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick00SiCoupe »</TD></TR><TR><TD CLASS="quote">
NO, blockguards are worthless IMO, the stock rods will do 300whp tuned correctly ya, but so will the stock pistons.</TD></TR></TABLE>
Couldn't say it better myself.
Do it right.
Spend the extra money or you wont be happy.
Do it right.
So where do I get my block sleeved and how much
...or does anyone have one for sale??
Thanks!
Thanks!
I believe Earl Is in that area of teh country, search for him and give him a call.
Ive never had any work done by him but ive only heard good **** about him.
Hondizzle!
08-16-2005 04:36 AM
