i need to run n/a for awhile what can i do with the tapped oil pan?
i just got done doing a re-build (on my motor) and for the time being i cant run my turbo, but my oil pan is tapped......so i was thinking i could just get a piece of hose and a bolt and kinda "cap" off the pan........would that work or does anyone else have any ideas? can i even drive with that pan (for now)?
Re: i need to run n/a for awhile what can i do with the tapped oil pan? (coneheadsracing)
I second just putting a bolt into the oil pan and remove the line for now.
Re: i need to run n/a for awhile what can i do with the tapped oil pan? (hatchinprogress)
ive done this before i just put a bolt right into the fitting and then put some silicon around it and it held fine
Re: i need to run n/a for awhile what can i do with the tapped oil pan? (nblkid)
what kond of fitting do you have on the pan? mine is a male AN fitting so i would need some kind of AN cap to close it off. if you have something with standard threads then you could probably just put a bolt and washer in it, kinda like the drain plug.
Re: i need to run n/a for awhile what can i do with the tapped oil pan? (JDM turbo DC)
Yeah, if you have a -10 male fitting on your pan you can use a -10 cap. They are like $1.25 a piece at my local hose supply place.
476 whp / 323 tq @ 17 PSI
Re: i need to run n/a for awhile what can i do with the tapped oil pan? (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic »</TD></TR><TR><TD CLASS="quote">Yeah, if you have a -10 male fitting on your pan you can use a -10 cap. They are like $1.25 a piece at my local hose supply place.</TD></TR></TABLE>
whats the name? is it somethin i can pick up at autozone or napa or sumthin?
i got my oil return male fitting from stan of fast-turbo, what is the threading? -10?
nm, i found out, it is a -10 AN male fitting. the silver piece shown here...
yeah a -10 cap should work nicely. if you dont have anywhere locally to get it (usually autopats stores dont stock stuff like this) than you can get it here.
http://www.anplumbing.com/shop..._num=
part# 992910
Modified by dpetro1 at 4:14 PM 2/1/2006
part# 992910
Re: i need to run n/a for awhile what can i do with the tapped oil pan? (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">yeah a -10 cap should work nicely. if you dont have anywhere locally to get it (usually autopats stores dont stock stuff like this) then you can check out you can get it here.
part# 992910</TD></TR></TABLE>
thanks! big help
thanks! big help
for the turbo oil send line, i have a oil pressure gauge and want the oil send line straight to the "sender" unit when i remove the turbo. do they also sell fittings male to female, the male for the oil line and female same threading as the back of the block. do you the threading for the fast-turbo oil send line and threading for the back of the block?
im pretty sure stan uses a bspt -> npt adapter for the block and then a 1/8npt -> -3AN union to hook the feed line to. so both hose ends are -3AN on the feed line. that site has plenty of 1/8npt to -3an fittings, male, female whatever you need.
try part# 981603 for the -3an to 1/8npt (male threads)
do you have the gauge and feed line both running off of the back of the block right now?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">im pretty sure stan uses a bspt -> npt adapter for the block and then a 1/8npt -> -3AN union to hook the feed line to. so both hose ends are -3AN on the feed line. that site has plenty of 1/8npt to -3an fittings, male, female whatever you need.
do you have the gauge and feed line both running off of the back of the block right now? </TD></TR></TABLE>
i dont, i have a T on the back of the block with no adaptor for the stock oil sensor and an oil line that goes straight to the firewall where i have another T for the oil pressure sender and for the oil feed line to my turbo.
the one i'll need is actually part #968703. male -3AN to female 1/8 NPT, right? im gunna gave the sender screw into the fitting and have the fitting screw into the line. check the part number to confirm dpetro1, thanks!
part# looks good to me. that way you can just connect the gauge sender directly to the feed line. are you going to remove the tee on the firewall and just run the line from the block straight to the sender?
btw, if you are going to order from that site i would try to buy as much stuff as possible because the shipping is kinda steep compared to the price of the fittings. but they are def one of the best sites for fittings and hose ends. i miss ordered from them once and needed just one more part that was like $1.50 and had to pay like $9 shipping. no big deal it just kinda sucks.
well i have 2 Tees, one from the back of the block for the stock oil sensor and an oil line to the firewall for my other T that has the oil pressure sender unit and another oil line for my turbo. im gunna keep the T on the back of the block to keep the stock oil sensor and just ditch the second T on the firewall. i want to keep that autometer oil pressure sender off the block, heard bad things about it. thanks again dpetro1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 »</TD></TR><TR><TD CLASS="quote">btw, if you are going to order from that site i would try to buy as much stuff as possible because the shipping is kinda steep compared to the price of the fittings. but they are def one of the best sites for fittings and hose ends. i miss ordered from them once and needed just one more part that was like $1.50 and had to pay like $9 shipping. no big deal it just kinda sucks. </TD></TR></TABLE>
yea i noticed that yesterday, they are raping me on shipping. i called them and they said its a minimum $8 1lb shipping and tax, well i only need 2 fittings. well i need it!
I picked up a -10AN cap from my local auto parts store, it was only a few bucks.
I also unplugged my oil feed line and inserted a threaded plug into where the feed line hooked into my oil distribution block.
Re: i need to run n/a for awhile what can i do with the tapped oil pan? (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">I picked up a -10AN cap from my local auto parts store, it was only a few bucks.
whats your shop called? whered you get that plug for the distribution block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC »</TD></TR><TR><TD CLASS="quote">whats your shop called? whered you get that plug for the distribution block?</TD></TR></TABLE>
I picked both those parts up from Baxter Auto Parts. They are only in the Northwest, I don't know where you live, but I'd think that most places would carry them, maybe I'm wrong though.
I picked both those parts up from Baxter Auto Parts. They are only in the Northwest, I don't know where you live, but I'd think that most places would carry them, maybe I'm wrong though. </TD></TR></TABLE>
PMed
PMed
