I need help!! RC 550 injector seals
I need some injector seals for some 550's. The factory injector seals are too thick for the injector to go into the intake manifold. I have searched.
-Can someone link me to somewhere that has a seal kit for my problem? -Can someone give me a part # for a seal that they know works from autozone or somewhere? -I know i can dremel them out but i just don't want to. TIA https://honda-tech.com/forums/images/smilies/emthup.gif p.s. NO "friend did this" or "I heard" please |
Re: I need help!! RC 550 injector seals (impound)
ANYBODY?
silicone spray lubricant.
worked well for me. |
put some motor oil on the seals. also, it helps if you stop being a pussy and push them down with the rail.
will go in no problem https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: I need help!! RC 550 injector seals (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impound »</TD></TR><TR><TD CLASS="quote">I need some injector seals for some 550's. The factory injector seals are too thick for the injector to go into the intake manifold. I have searched.
-Can someone link me to somewhere that has a seal kit for my problem? -Can someone give me a part # for a seal that they know works from autozone or somewhere? -I know i can dremel them out but i just don't want to. TIA https://honda-tech.com/forums/images/smilies/emthup.gif p.s. NO "friend did this" or "I heard" please</TD></TR></TABLE> well i ran into this exact same prob about a year ago when I first went to my rc550's I searched and searched and couldnt find shit, finally I decited there was no way a little thing like this was gonna hold me back, I just used a dremel to wallow out the center of my old ones. I was dead set against riggin em up for a while, but it just seemed like to easy of a fix to let it hold me back any longer. It worked perfect and is still holding up fine. just take your time and there wont be any probs https://honda-tech.com/forums/images/smilies/emthup.gif |
wait what exactly is the problem? the seals wont go into the mani or the injectors wont go into the seals? you should install them in this order.
1. put the seals in the IM 2. put the injectors in the fuel rail. 3. put the rail on the IM and center the injectors in each seal. 4. tighten rail and make sure injectors stay centered. the injectors will sit on top of the seals not inside. they are suppose to be that way. i can link you to the RC instructions if you have anymore questions i just dont have them on this computer. |
Re: I need help!! RC 550 injector seals (dpetro1)
wow finally some responses!! unfortunately not what i am looking for!
-although my pussy does hurt sometimes its not the o-ring into the rail i am having a problem with confucioussae -silicone works wonders. thanks, i know -JRSC01GS-R thanks for the response. i did post at the top i don't want to dremel the stock rings out. i started doing one and i am just not pleased with the inconsistency i was getting. -thanks all for the responses. i found some from ben@importparts. cheers https://honda-tech.com/forums/images...es/emsmile.gif https://honda-tech.com/forums/images/smilies/emthup.gif |
so you were talking about the seals in the IM? what was the problem. everything supplied from RC should work just fine
