I need 3 inch ic piping for a h22 in a 94 hatch.
Hey guys just finishing up and i need 3 inch pipe kit preferrably aluminum, the intercooler will be 30.5 end to end, i also prefer the pipe to be bead rolled on the ends too. This is a h22 into a 94 hatch. Dont have to be perfect i can modify a little if i have to.
Does anyone know who sells a kit like this?
Re: (b16sedan)
thats right. My inlet and outlet on my intercooler is 3inch, I am running the pt71GTQ which is the h housing which has a 3 inch outlet. I think i know what im doing. Plan on running 750 plus whp.
Re: (b18prl)
would it be any good to run 2.5 into 3in piping my endtanks on my cooler are 2.5 i think but i do have a 70mm t.b and a t66 t4, (not sure on the specs)
I think 3/4" pipe should be good for 700hp=] I think your best bet is to buy u-bends and do it yourself. If you cant weld it would be cheep for a shop to weld up a few peices and bead the ends. But I think an aluminum b.o.v. flange might be hard to find unless its already on your intercooler. I know tial makes them though.
Re: I need 3 inch ic piping for a h22 in a 94 hatch. (slow poke)
doing more research, i think 2 3/4 mild steel will do ok. anyone that has these?
Re: I need 3 inch ic piping for a h22 in a 94 hatch. (9sech22civic)
like i was sayin the shop doing my set up is using steel... i wanted alum. but o well... i think they are doing 2.5 from intercooler up to 3in in by the charge pipe... 3in downpipe & exhaust w/ cut out also. thats why i asked if that was a good idea. and if theres any pros or cons to goin from 2.5 to 3
Re: I need 3 inch ic piping for a h22 in a 94 hatch. (UltRaH22)
i got my 3" aluiminum thru k teller good prices ,,,,,,, obviously u will have to fab it yourself
Re: I need 3 inch ic piping for a h22 in a 94 hatch. (h22 civic)
not sur eif this helps but what the hellhttps://honda-tech.com/zerothread?id=1109174
thanks for the reply everyone, but i guess i'll stick looking for a 2.5 mild steel. You guys know anyone that can make me one or has one for sell. h series in a 94 hatch?
