I know you guys like to guess power outputs... so humor me! 3 weeks away and I cant wait!!
I have been waiting for what seems like forever to finish this pos... and now it's finally close. The setup is below, what do you guys think it's capable of? I'm kinda hoping for 550 whp, on 110 octane, and et's in the 10.7 range
B18c1 Head
Crower 63411T-2 Cams
Ferrea Stainless valves
Crower Titanium Retainers
Skunk 2 Springs
b18a1 block 85 mm darton sleeves
JE 9.1s
Eagle Rods
Stock LS Crank
GSR trans w/Quaife & PG Cradle
Skunk 2 Drag coilovers
Tokico Blues
Traction bars
Spec Stage 5 clutch & pp
Clutchmasters 8lb flywheel
GT35
Custom Top Mount
3" Dp/Exhaust
HKS SSQ
Tial 38 mm w/1 bar spring
PWR 750 HP Intercooler
2.5" Charge Piping
Skunk 2 IM
Edelbrock 68mm TB
MSD 7al 2
MSD Pro Power coil
MSD 3 step
1000 cc precisions
Walbro 255
-8 feed, -6 return (stainless)
Aeromotive FPR
Aeromotove Filter
P28 - Neptuned!
Modified by slowteg550 at 8:45 PM 6/20/2006
B18c1 Head
Skunk 2 Springs
JE 9.1s
Eagle Rods
Stock LS Crank
Tokico Blues
Traction bars
GT35
Custom Top Mount
3" Dp/Exhaust
HKS SSQ
2.5" Charge Piping
Skunk 2 IM
Edelbrock 68mm TB
MSD 7al 2
MSD Pro Power coil
MSD 3 step
1000 cc precisions
Walbro 255
Aeromotive FPR
Aeromotove Filter
P28 - Neptuned!
Re: I know you guys like to guess power outputs... so humor me! 3 weeks away and I cant wait!! (slo
sounds like it will make what you want it to but the only thing I would change if it where me where the size of the pistons.... I would run either 83 or 84mm because at 85 you have no room for rebuild
I know... but I got a hell of a deal on the block, already at 85 (actually mic's at 84.6)... so I jumped on it.
well thats good.... not to sound like a dick or anything but I hope you can get another good deal if something goes wrong because that will be another atleast lets say around 1700 for pistons, sleeves and machining work...... but I hope all works out for you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg550 »</TD></TR><TR><TD CLASS="quote">
i predict problems.
especially with the cams and the crower retainers. we had a set of crower retainers pull through on us.
Sav Leone, just cracked a cam a month or 2 ago @ E-town, and if you search around on here, you will see many others have also cracked their crower cams
the phantom grip cradle DOES NOT give enough clearance between the gears, so there will be problems with that as well.
a better cradle which does give the gears "proper mesh" is the http://www.libertysgears.com transmission cradle. and its cheaper too. comes with shims/bearings and a hell of a good tech line, if you should happen to have a question
i predict problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 »</TD></TR><TR><TD CLASS="quote">what about injectors...</TD></TR></TABLE>
updated the list... 1000 cc precisions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">
i predict problems.
a better cradle which does give the gears "proper mesh" is the http://www.libertysgears.com transmission cradle. and its cheaper too. comes with shims/bearings and a hell of a good tech line, if you should happen to have a question </TD></TR></TABLE>
I'll just have to hope that the retainers hold up... the cams have like 3 k miles on them, so I'm hoping if they were gonna break due to poor metal structure, they would have already done so. The tranny has already been ran for about 50 passes at the track, no problems....
i predict problems.
best of luck to you man, you are really going against the grain with some of those parts. i hope everything works out in your favor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">best of luck to you man, you are really going against the grain with some of those parts. i hope everything works out in your favor </TD></TR></TABLE>
Werd.
What chassis is this going into?
Werd.
1hp.
it blows up on the dyno is my guess sorry had to be the one to be neg.
haha... if this ****** blows up on the dyno they'll be a massive part out and I'll buy the s2k I want along with a Grand National project car
What boost setting!?
I could see you hitting your goals, I'm going to say 538whp annd 313lb/tq.
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg550 »</TD></TR><TR><TD CLASS="quote">haha... if this ****** blows up on the dyno they'll be a massive part out and I'll buy the s2k I want along with a Grand National project car </TD></TR></TABLE>
now youre talkin. hit me up if that happens. i miss mine.
