I know I need to clock the turbo but.....
Which side do i do it on? The Sorry for my terminology, but just to make sure I got it right I'm going to ask like this- Do I undo and thurn on the light silver side, or do I undo and turn on the Darker side. This is for the turbonetics turbo that comes with the drag kit.
Re: I know I need to clock the turbo but..... (CleanSi)
Basically make sure that the oil return line is on the bottom of the turbo....Clock either side...they both will turn...it just depends on what you need.
Jason
Jason
Re: I know I need to clock the turbo but..... (Blown90hatcH)
Ok thanks, now I have a question about the "an" fitting. It says bolt it up to the middle section of turbo, now there are two sides that his can go to, which one? And which 90 degree angle fitting is it, there are three, two are alike and then the solo one. Thanks for your help.
On most turbo's there is only one side that is threaded. That is the side for the an fiting and the feed line.
