I just picked up a Holset H1C... Should I use this?
Im just wondering if anyone has used a H1C (similer to HX35) Holset turbo on a B18 before. Im just wondering how the spool is? Is this a T3 or T4 flange? Shoul I use a oil restrictor in this or just run a 3an or 4an oil line. I got the turbo very cheap off a friend so i figure I can give it a shot. Anyways what are you guys opinion of this turbo? I am planning a built ls/vtec with a one-fab top mount manifold I am hoping for the 400hp range, will this turbo provide me with what I want?
It's a t3 flange
It won't be necessary to run a filter on the holset
and depending on what it came off of - the H1C can have anywhere from a 12cm^2 turbine housing all the way up to a 21cm^2 turbine housing.
If you call holset and give them the assembly number - they can tell you EVERYTHING about it.
Very good customer service at Holset
going for 400 w/ a holset hx35 w/ 12cm housing....
lsvtec
forged internals
9:1 cr
1857cc
ge HS's
acl bearings
eq length mani
3" dp to cutout
uberdata tuned...
being built every night for the next 2 weeks
lsvtec
forged internals
9:1 cr
1857cc
ge HS's
acl bearings
eq length mani
3" dp to cutout
uberdata tuned...
Re: (Tchleung)
I like the HX35's. Cheap, and for a budget big HP setup, you cant beat it.
A friends LSvtec on OEM internals, B16 cams, log mani and an HX35 recently made 321whp on 13psi. Spool up is a bit soft, but the TQ hits right after crossover at 5300.
Youll like it.
Youll like it.
TheIntegraGuy
08-25-2005 02:55 PM
Acura_I-RS
03-30-2003 09:17 AM
