I Just got a drag kit install is my ngk plugs running lean,rich or its normal?
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (eg6junkie)
Danm thats good to hear..thanks peep for the detail..
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (JDMDC2909)
Oh yea one thing my check engine light came on which is throwing a 45 meaning its running lean or either rich.. so I dont know what that mean..so i just reset my ecu..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hotrex »</TD></TR><TR><TD CLASS="quote">whats your engine management look like. </TD></TR></TABLE>
does'nt the white tip indacate pre-fire?or too hot of a spark plug?
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (0vrbst_t66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0vrbst_t66 »</TD></TR><TR><TD CLASS="quote">does'nt the white tip indacate pre-fire?or too hot of a spark plug?</TD></TR></TABLE>
No I'm pretty sure that white is just what you want.
Did you take those plugs right out after going for some WOT runs? The plugs go through heat cycles which basically "erases" the evidence of lean/rich detonation, etc...
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (Boltz)
I ve been driving 2 days with those plugs in...So am I OK?
Looks a hair on the warm side. What did you do about your timing?
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (MarkC)
I always assume that was LEAN as ****. >_< Or was it just me.
My tune is within 12.5:1 and 12:1 in boost. And my plugs looks golden brown, isnt this whats everybody aiming for?
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (D3LSLO)
to me those look lean...you want golden brown
"read plugs" in search on archived returned 14 results with PICS!
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (gsrsp33d)
What do I need to make it run right..just the basic for now later in the future goin to go stand alone..what you guys suggest?
My friends at hook ups told to get a vafc,fuel rail,fpr n tune it..if not that get rc 310cc and 8.1 fmu is that ok?
those plugs look about just right for a boosted car....like stated b4 a tad on the lean side...are all 4 exactly the same...if so your set
standalone is always best...it will prolong the life of your motor with nice a/f mixture curve and timing plus tuning=more power
Re: I Just got a drag kit install is my ngk plugs running lean,rich or its normal? (GunMETAL_TEgRa)
Yea all 4 is the same..I took them off after I gun it on first to second gear then pulled over and pull the plugs out..
