i got the fuel pump to work.....now where to remount the fuel guage?????
i finally got the inline pump working now the fuel pressure guage reads at 0-20psi..........i have it mounted on the inlet side of the fuel filter and i ran the fuel pump between the outlet of the fuel filter to the fuel rail so where is a good place to put it so that it reads correctly..........i also have a b & m fuel guage and a fuel pressure regulator
Re: i got the fuel pump to work.....now where to remount the fuel guage????? (uneekcrx)
What motor do you have, I tapped the end of a b16 fuel rail. It has a brass plug at the regulator side. I drilled it out and tapped it for 1/4 NTP threads, got a 1/4 to 1/8 NTP reducer, an elbow, and screwed the guage in. Works great. The B18C fuel rails are cast and have no place to tap. Hope this helps.
iNetForce
11-13-2005 08:27 PM
