How to use Hondata S200 to control water injection
Does anyone know exactly how this is done and how does it work? Im thinking using the negative output for nitrous, to trigger a relay to activate the water injection pump.
If someone can please give a clear explanation of what wire goes where, and etc. thanks
Re: How to use Hondata S200 to control water injection (integra123)
Hondata's site should give instructions on hooking up nitrous solenoid control, I'd just take that output and use it to flip the relay that powers your pump.
Minor Threat, Blundar, and I have been talking about wiring a second Honduh ECU in parallel with a 12K resistor to spoof IGO and the injectors circuit controlling a secondary set of injectors. 3D water injection mapping, zero it out when unneeded, and precise control of water:fuel ratio at any point in the mappings. Hope it works, would be the absolute pimpshizzle.
Re: How to use Hondata S200 to control water injection (Si Shane)
We're not 100% sure a second ECU in parallel isn't going to throw off sensor readings, but I'll probably attempt this sometime this summer. Nothing ventured, nothing gained, so so cross your fingers!
Re: How to use Hondata S200 to control water injection (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">We're not 100% sure a second ECU in parallel isn't going to throw off sensor readings, but I'll probably attempt this sometime this summer. Nothing ventured, nothing gained, so so cross your fingers!</TD></TR></TABLE>
Good luck joey.
Good luck joey.
TB123
Engine Management and Tuning
10
04-16-2011 07:54 PM
fearthis4
05-03-2009 08:48 PM
Kwuaymaikrup
12-27-2003 01:00 PM
