How to tell if injector seals are leaking or not
How can you tell if you have a vacuum or boost leak with the injector seals between the intake mani and injectors. I think I might of bored them out too much http://images.honda-tech.com/set1//smile/emcrook.gif
Re: How to tell if injector seals are leaking or not (sporkcrx)
bump cuz i wanna know too for when i start my car soon.
Re: How to tell if injector seals are leaking or not (tegsedan)
how come you had to bore them out ?
Re: How to tell if injector seals are leaking or not (JonnyDanger)
i bored mine for the dsm injectors, he probably did the same
when i did my first dsm install, i too bored one seal a little to much. Found out because it leaked fuel right out:(
Re: (1CiViC1)
Yea I'm using the DSM injectors. So fuel just leaked out?? That area isn't under pressure though, it seems like the engine's vacuum would pull the spray in?
