How stupid is this? Please Honda-tech, knock some sense into me
I finally got my jdm single cam turbo going at 7psi, and it pulls nice.. Really nice, but maybe not nice enough. I have a .50 trim t3/t4, and I'm putting dsm 450s in it tomorrow. I was considering selling it and looking into an rb25. Am I jumping the gun? I dont really mind the lag too much, I just want to go fast... "I seen the way you drive, you got a heavy foot.." well thanks dom torreto, its because I FINALLY turboed my car and am pretty amped about it. what would benefit me more?
Re: How stupid is this? Please Honda-tech, knock some sense into me
built motor???
All I have in my d16z6 is wiseco pistons eagle rods and a fresh rebuild on the head. I'm boosting 13 lbs prolly making a lil more then a rb25........and in a light civic. I'm running 450cc injectors in mine, but if I were running bigger injectors I'd be making 300 easily......
Is your single cam running an fmu, or stock injectors? What's in it now? If it's not a full tune on something like S300, ectune, neptune, then you're also harming the turbo's spooling.
If you really want faster spool, get a 2.0L vtec setup. It will be far less hastle, as well as less expensive. What you should really do is get something like a 50trim T3, larger MAP sensor, and run 15-18psi. It will spool much faster, and make similar power to 7psi on that turbo.
when you say 2LV set up are you referring to a b20v? That would be awesome for down the line, but as of right now I'm more into working with what I have. I'm considering buying a blown sc and doing the vitara/eagle rod set up.
Thanks for the info, got to learn to right your wrongs somewhere. I figured this was a little anticipated seeing as how I dont even have my tune/injectors on, but I've never had a turbo honda and dont know how big of a difference it will make
fuel injectors are extremely important. you might get away with it for a while but over-working stock injectors can lead to a sudden injector failure, which in turn causes a huge lean-out, which THEN turns into destroyed engine parts.
i dont think injectors will make you faster on the same boost, but it will be much safer, and allow you to turn up the boost farther (though i dont recommend more than 8psi on stock internals)
studs and gasket are on the list for the future- by future I mean next couple of weeks. I want the h-t opinion on whether or not my turbo is either to large and I should go smaller to go faster, or I'm completely over thinking it and a heeuge idiot. should I be looking into this rb25 where maxing it it out is still in my power band or keep the 50 trim?
well as an example. im using a tiny little td04 14b mitsubishi turbo and on 8 psi i put down right at 240 hp on a b16 with stock internals and a slightly thicker head gasket. spools quick as ****.
THAT rules dude, but whats better a quicker spool with quicker max out, or a lag and longer spool?
depends on your goals. i wanted to have a fun fast spooling car that could lay respectable low thirteens at the track and sound like god yelling as i drive bye. lol. and i have succeeded.
I never really focused on spool as much as a GTFO of my way noise (open dump+RFL). I came to this conclusion tonight- All I want to do is eat ******** in their eclipses. I'm not really too worried about off the line since getting ahead in the beginning doesn't mean you will win
Last edited by everythingwentblack; 09-13-2009 at 08:49 PM. Reason: I like to touch balls
"I never really focused on spool as much as a GTFO of my way noise (open dump+RFL). I came to this conclusion tonight- All I want to do is eat ******** in their eclipses."
LMAO, that just made my night.
am i missing something ? do you even own a nissan ? , since you keep bringing up a RB25
Your car is going to have hard time running (if at all) with those 450's with no tune. You cant just throw bigger injectors in and expect it to run.
So I have come to realize... that just makes today that much easier since its one less thing to do
HOw stupid is this ? ... Not stupid, but reality. You expect too much without taking proper steps in getting there. If anything your post spells less than amateur builder. No tune, stock injectors, health of motor ? , stock exhaust ? , and WOT because you finally got it running ??? ... It's not running until you get it tuned, with proper Air-Fuel ratios. Learn to do it proper and don't Bit*h.
haha in my defense of not sounding completely retarded, I was mentioning spool in reference to short spool vs long spool to cadeMFjohnson comparing his spool times to mine
for the record I have a jdm single cam with 18k miles on it, tanabe hyper medallion catback. That doesn't change anything and make me look like a better person or you less of a ball touching dude kissing high five-in maniac. Dont talk to me like some ******* and tell me things I already know. We all can ask stupid questions here and there, this is mine.
Set a power goal for yourself (based on our injectors, because you'll be limited), get your DSM 450's, headstuds and head gasket in, get it chipped and tuned, and have fun.
[/THREAD]
Then keep your t3/t4 50 trim. It reaches maximum pressure rather quickly (even for a d15), and it wont run out of breath before the d15's stock redline (depending on what turbine housing you have).
[/THREAD]
[/THREAD]
If I were you, I would not run those stock injectors, even if it IS a street tune on 7 psi. Install your 450's, you can always swap them when the Vitara motor is done.
And I sure hope you're tuning with some form of engine management RIGHT NOW, instead of an adjustable FPR alone.
