How are SI B16a2 Turbo-ed?
Old 09-10-2003, 01:02 PM
JDM CTR EK's Avatar
Default How are SI B16a2 Turbo-ed?
I keep hearing that SI motors are no good when Boosted. I was told that the torque was weak. I keep hearing about SI's running 14's - 15's with 8-10psi. Can anyone tell me different or same?
I am lookin' for a motor right now and I plan on boostin' it. Found a good deal on SI. Should I do it is the question.
Old 09-10-2003, 01:08 PM
ebp 99 si's Avatar
Default Re: How are SI B16a2 Turbo-ed? (JDM CTR EK)
i ran 13's on 7psi
Old 09-10-2003, 02:07 PM
Maxime's Avatar
Default Re: How are SI B16a2 Turbo-ed? (ebp 99 si)
13.738 @ 7psi untuned!
Old 09-10-2003, 02:09 PM
ProEater's Avatar
Default Re: How are SI B16a2 Turbo-ed? (Maxime)
https://honda-tech.com/zerothread?id=615546
try that thread!
ill post my numers when i finish my set-up....
Old 09-10-2003, 02:30 PM
HXMan's Avatar
I ran 13s on 7psi with a b16a2 also.
b16a all motor.
b16a FI
Old 09-10-2003, 03:23 PM
FredoSP's Avatar
Default Re: How are SI B16a2 Turbo-ed? (HXMan)
or a B16 with 84mm bore yumm.... but then again its more like 1.7X - 1.80 L
Old 09-10-2003, 03:53 PM
el arbi's Avatar
Default Re: How are SI B16a2 Turbo-ed? (FredoSP)
damn, awesome, 13.7 at 7psi = amazing. very impressed
Old 09-10-2003, 04:07 PM
VisualAutoMotoring's Avatar
Default Re: How are SI B16a2 Turbo-ed? (99SiRacer)
my B16 on 10psi
Old 09-10-2003, 04:11 PM
Disco Stu's Avatar
Default Re: How are SI B16a2 Turbo-ed? (PRojectSi2)
HAHAHAH....done and DONE!
Old 09-10-2003, 04:15 PM
Sleepin''s Avatar
Default Re: How are SI B16a2 Turbo-ed? (Disco Stu)
LOL! N/A B16 with power is just a pipe dream unless you are an engine god...or have a lot of $$ to throw away.
See sig.
Old 09-10-2003, 04:18 PM
lazerus's Avatar
Default Re: How are SI B16a2 Turbo-ed? (Sleepin')
torque is so overrated.. imagine how much torque an F1 indy car makes..
Old 09-10-2003, 04:24 PM
AlLMoToRvOtEr's Avatar
My buddy Twistedhatch who is a honda-tech member also had a SIR 2 Stock motor fully tuned with hondata on 11psi and his car ran 12.94 while it blew up. But the thing was that he launched it at like 7500 RPM's on 24x8 Bogart's and it about died because it didn't have enough torque to pull it outta the hole. Where as his stock B20 ran exactly the same thing with about 50 less hp but it had enough torque to get off the line. So you can see the 2 differences but the more torque you have the better you are gonna be.......................
Old 09-22-2003, 10:53 AM
Mikeman191's Avatar
Default Re: How are SI B16a2 Turbo-ed? (turboDC2)
are we talking the USDM or the JDM b16a2? Im running the SIR2 block (170hp, p30 pistons).. and i was wondering the same thing.... any issues w/ detonation?
Old 09-22-2003, 11:01 AM
TwistedHatch's Avatar
Default Re: How are SI B16a2 Turbo-ed? (Mikeman191)
ya it was the jdm sir 2 170hp.........as far as i know there wasn't any detonation, at least that you could see on the plugs, it was tuned at like 11.8psi wich is right below what the stock map will read and it ran perfect........i think it was just too much pressure for the stock pistons, it cracked a ringland or something, the thing still runs just smokes a tad......
Old 09-22-2003, 11:19 AM
SpdFrk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM CTR EK &raquo;</TD></TR><TR><TD CLASS="quote">I keep hearing that SI motors are no good when Boosted. I was told that the torque was weak. I keep hearing about SI's running 14's - 15's with 8-10psi. Can anyone tell me different or same?
Who ever told u that is ******* moron.
Old 09-22-2003, 11:22 AM
baphomet's Avatar
Default Re: How are SI B16a2 Turbo-ed? (SpdFrk)
** VIDEO ** Who ever said b16's were useless? / Stock b16 / Precision sc63 / Full-Race / 11psi
Old 09-22-2003, 12:01 PM
can I haz?
thid92's Avatar
i just went for a ride in a B16a1 turbo CRX tuned at 15 psi and made 255HP that thing pulled hard as hell. i have a vid of it in the appearance forum under the CT meet.
Old 09-28-2003, 09:22 PM
JDM CTR EK's Avatar
Default Re: How are SI B16a2 Turbo-ed? (jerseykid609)
Keep posting please. I am still tryin to figure out if i should just buy an SI motor now (jdm b16 170hp) or just save a lil' more and get a b18c1 (jdm gsr). No matter what it's going to be turboed in a few months afterwards.
I just don't know if i should just used the saved money from the B16 and use it towards a turbo kit.
Old 09-28-2003, 09:47 PM
JDEM1's Avatar
i say save some money(get the b16) and put it towards your turbo(hondata), i have a '00 si stock internals 241whp & 158lb torque @6.5 psi
Old 09-28-2003, 10:28 PM
r7
r7's Avatar
Default Re: How are SI B16a2 Turbo-ed? (JDEM1)
i making 245whp and 178wtq on 1990 b16, @ 7psi ..
sig
Old 09-28-2003, 10:39 PM
New User
94cxhybrid-T's Avatar
Default Re: How are SI B16a2 Turbo-ed? (r7)
what was your setup. i keep reading about how you are making this amount of power and i am beginning to think that my motor is fucked up or that i have a weak link in my setup. I made 241/172 at 7lbs in a stock block gsr with skunk2 manifold, revhard kit, and greddy sp exhaust hondata and 550's. Do you think the exhaust is ******* me up??
Here is my dyno sheet:
Old 09-28-2003, 10:45 PM
slowsi00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">
Who ever told u that is ******* moron. </TD></TR></TABLE>
ran a 13.8 at 104mph at 6.5psi on fmu with my b16.
street tires.
Old 09-28-2003, 11:22 PM
r7
r7's Avatar
Default Re: How are SI B16a2 Turbo-ed? (slowsi00)
that gsr turbo should be making more power, even with that exaust.. .
check compression
check plugs
whats the afr under wot?
maybe it was tuned fairly rich?
Old 09-29-2003, 05:54 AM
ykracing's Avatar
Granted this is a full-out drag car, but I ran a 10.985 @ 124.68
with a stock block, stock head b16....
it dynoed at 300 whp & 201 ftlbs... at 11psi
since then I have raised the boost to 13psi and ran the 10.9....
hope this helps
Old 09-29-2003, 06:36 AM
Happyman's Avatar
Default Re: How are SI B16a2 Turbo-ed? (trboCIVICWRX)
haha boostsohfast ran 13.6 on 7 psi with a sohc vtec with a 15G turbo. :-P
Quick Reply: How are SI B16a2 Turbo-ed?
